VSE: Continuus Camstudio clip changes framerate after an image clip. #44760
5 Participants
Reference: blender/blender#44760
Tested on Windows 7 (gtx970) and 8(no information of the gpu here).
Broken: 2.74 (
000dfc0
) [2015-03-31] Official blender build from website.Short description of error
We have a camstudio video imported into the vse. We add now a image to the vse and put it somewhere above the video sequence. The image is displayed shorter than the video and doesnt interrupt the video clip.
When rendering the video the framerate changes after the imageclip was passed. Before the image clip it renders at normal speed, after passing the part with the image the framerate doubles. The video ends therefore way to early. The sound doesnt get played faster and ends at the expected time.
Upon deleting the image, blender renders the video as expected.
Open the attached blend and just render the file.
Delete the image to see it rendering correctly.
blend test.zip
Added subscriber: @LinoThomas
Added subscriber: @Psy-Fi
Confirmed, will take a look
Added subscriber: @Blendify
Any news?
Added subscriber: @ideasman42
Confirmed and looked into it.
Whats happening is the image causes the frames of the video not to be read. Then when the video shows again,
(as far as ffmpeg is concerned) this is read from a random location in the video stream.
This also happens if you remove the image shift the start of the video to where the image ended. The duration of the slowdown is the same too.
Ideally Blender would prefetch frames to avoid this (or handle the codec better).
However this is more an area to improve, rather than a bug.
For now, you can work around the problem by using codecs which better support random seeking. (lots of info about this online, you could try simpler codecs such as mjpeg, or you could enable proxies which use timecode to improve seeking).
