Scopes in Image Editor make masking painfully slow #44761
Reference: blender/blender#44761
OSX 10.10.2 GTX 660ti
Broken: 2.74.5 (
183b643
)Worked: (optional)
Scopes in Image Editor make masking with Viewer Node as input painfully slow. I realize that this issue has been brought up in other instances before, with the simple answer "close the scopes panel". But the scopes are a Tab in the toolshelf, and for masking the user needs the masking tools as well, so the toolshelf has to be open. But scopes seem to be calculated even though the scopes tab isn't visible.
So maybe one way to fix this would be to make scopes aware if their tab is open. Or just make them smarter on when to update. Or make a button "use scopes".
Apart from that I think it is also annoying how much scopes slow down rendering. Even if the "Lock interface" button in Dimensions panel is pressed...
Open attached file, do a render, try to edit the mask. Notice how slow it responds to user input. It gets a lot better when toolshelf is closed.
masking_scopes.blend
Added subscriber: @sebastian_k
Added subscriber: @Psy-Fi
I've looked at tab detection in the past and it's not so easy. Other possibility is to disable them completely just like in paint mode
Added subscriber: @Sergey
Co-incidentally enough was looking into making scopes more realtime, but it's quite tricky to do actually -- computation is not so difficult, so even making it threaded makes it so worse CPU cache utilization kills all the performance. So started to think that it could make sense to make scopes a job, similar to the material update. This way it'll be possible to suspend actual scopes calculation for a few moment, allowing other tool to work and re-trigger update. And actual update will happen after tool started modifying the image.
Added subscriber: @mont29
Scopes are painfully slow , this is old known TODO, no need to keep a report about it. ;)
Just for the sake of completeness, I am not complaining that scopes are slow (well, sure, I would love to have them faster). I am complaining that they slow down masking even if I don't have the scopes open.
