transparent speculars in raytrace method bug #44777
Reference: blender/blender#44777
windows7 64
ASUS ATI Radeon HD6870
Broken: (All)
Worked: (None)
raytrace transparency.blend
open, celect rendered shading mode, change transparent specular influence - we will see this bug
Added subscriber: @Inwader77
Added subscribers: @mont29, @Sergey
Can confirm the issue. Not sure whether this is intended/known limitation/bug… Tried to spot origin of the issue, but got lost in BI maze - all I can say is that
shade_material_loop()
gets a zeroshi->spec
for fully transparent specular with ztransparency, while it always getshi->spec == 1.0f
in raytrace case… That does not explains the difference of behavior for non-zero spectransparency though. Andshi->spec
is directly copied from material settings afaict, so… I’m lost for now! :PAlso, note that this only affects combined pass, if you render sith transparency instead of sky as background you get expected results (so alpha value itself is correct).
This effect is a bit tricky for raytracing. Not saying it's impossible, but changing the things will likely cause some compatibility breaking and require some refactoring of the shading loop in internal.
We currently don't have maintainers to do this, and its known issue which is a part of TODO. I've made sure it is listed in our wiki page now http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Render#Render_Engine
So thanks for the report, but archiving it as a TODO now.
