Group Instance, empty rotation
Windows 8.1, Nvidia GTX 670.
Test with Blender 2.74 (000dfc0) steam version and 2.75 testbuild (148ed4e).
With instance groups, shader don't use rotation to my empty object.
File test https://mega.nz/#F!TAkwRIxa!IrMfpjSV9syLntMSrJK1HQ
Opening file "scene_rendering" and rotate object "Tapis_de_table". Mesh turn, but not the texture.
Antonis Ryakiotakis (psy-fi) changed the task status from Unknown Status to Archived.May 22 2015, 3:06 PM
Antonis Ryakiotakis (psy-fi) claimed this task.
This is correct. The shader uses the object coordinates of the original object, which is not rotated. If you want to get the texture rotated properly, you need to remove the object from the field, which should use the instance rotation instead.
