OpenCL - CPU + GPU + GPU = Crash #44831
5 Participants
Reference: blender/blender#44831
Windows 7 64bit
Nvidia GTX 680
AMD R9 290X
AMD FX-8350
Broken:
Worked:
- OpenCL on GTX 680 - worked
- OpenCL on R9-290x - worked
Application crashes when rendering
With attached file. When changing rendering from CPU to GPU and in user preference changing the OpenCL device to FX8350 CPU, it crashes. If selected in user preference all devices (CPU + Nvidia GPU + AMD GPU) it also crashes.
Lack of option to select Nvidia GPU + AMD GPU OpenCL devices to test if the error is simply caused due to the OpenCL CPU code.
INcluded file does not have every element linked (as the HDR - hence purple hue - so that can be ignored?)
table2.blend
Added subscriber: @Prodeous
Added subscribers: @Sergey, @ThomasDinges
I can confirm crashes here with Intel i7 + Nvidia Geforce 540M on Windows 7 x64.
It's the Intel device that crashes here, the Nvidia one alone works fine.
@Sergey: We might want to limit multi device somehow? Vanilla Master (without environment flags) will use both split and mega kernel and different feature sets in such a setup. Ideally this should only result in render differences per tile, but there might be something else that goes wrong.
@ThomasDinges, it is handy to keep CPU OpenCL working for the development purposes. the option is not whitelisted by default as far as i concerned, so any use of it is kinda "on own risk" and "for investigation purposes only".
I can not reproduce crash on my laptop with windows 7 and i5 CPU, regardless if it's just CPU or CPU+GPU (GPU is gt520m).
What's the version of intel opencl sdk you're using?
I got it from here: https://software.intel.com/en-us/articles/opencl-drivers
"OpenCL™ Runtime 15.1 for Intel® Core™ and Intel® Xeon® Processors for Windows* OS (64-bit & 32-bit)"
@ThomasDinges, excellent. So did i =/ Will give it another attempt to reproduce the issue again later.
One more question tho: are you using own builds or builds from buildbot?
Self build (Scons), but I double checked with "blender-2.74-7fd93dc-win64" from Buildbot just now and it crashes as well, default cube scene and the blend from this report.
Assigning BF Blender: Next project sine it's nice to have this addressed prior to RC.
I would recommend that for current release the CPU option is disabled till solution is in place. Most people do not know the option is "on own risk" and "for investigation purposes only". If we see this option we would like it to not crash the applicaiton.
additionally i'm curious why I can't select just both of the GPU's (680+r9290) excluding the CPU option. I want to test if the two GPU's can cooperate in one render.
If you can see non-AMD GPU in the OpenCL list without setting any of the environment variables then there's bug in the device enumeration.
If you're setting environment variable then you're expected to see all the devices. By setting the variable you're already agreeing that there might be some issues. Forcing CPU from being always disabled is the wrong solution because while it crashes for someones for others it works just fine.
Added subscriber: @MartijnBerger
Well our multi device does not show all combinations of devices possible. The combo box selector thingy would become very very very long in some situations and this is technically not hard to solve but it involves touching the UI.
This issue was referenced by
cf19012fb0
This issue was referenced by blender/cycles@6f24f462fa
