bge KX_GameObject.localPosition affect KX_GameObject.worldPosition instead #44847
Reference: blender/blender#44847
any (tested on lenovo R400 with Intel and on AMD 4core with Nvidia GTX460
Broken: 2.73, 2.74 and 2.75 testbuild1
when setting Object.localPosition, it sets Object.worldPosition instead
https://www.blender.org/api/blender_python_api_2_62_release/bge.types.html#bge.types.KX_GameObject.localPosition
attached .blend demonstrate that trying to steer the default cube on local Orientation based on a localPosition speed doesn't work, the movement is linear and the cube is rotating on itself instead of turning following a curve ... localPosition-bug.blend
Added subscriber: @Olm-e-9
Added subscriber: @Sergey
Added subscriber: @JorgeBernalMartinez
I confirm the bug.
I was mistaked. This is not a bug.
localPosition is the object's position relative to its parent and is the same as worldPosition when there is no parent. If you want to move the object along its local axes, create a movement vector, rotate it by the object orientation matrix, then add it to the objects position.
You can replace
by
Thanks for reporting
Well ...
1 : I I know multiple manner to do the same effect, it's not the point, but thanks, this add another,
2 : so either it must be renamed "relativeParentPosition" or it has to be added with emphasis in the blender documentation, because it is not coherent with the internal blender usage where you have local and world axis that have nothing to do with parenting... and then it still lacks a function localPosition coherent with the blender interface :
if you play with local axis in the blender interface you would have the described behaviour, not the one you describe.
and it is not coherent with basic physics principles of relativity, and so confusing both with interface and intuitive understanding...
in conclusion : to me it is a bug, somewhere, and not a wrong assumption of my part: spending one day to understand what the behaviour of that function is, and having yourself confirming the bug in the first place is well the proof that there is one. Please give better arguments if you have on the contrary,
tks
well, my confirmation was done quickly between 2 day-job tasks. But I'm with you that the bge api documentation has to be improved.
I add this request as my particular TODO for the modifications that I want to do for this part of bge api (among others like reference or .copy(), etc).
Apart from this, I close the report as it is not a bug (localPosition works as intended).
Thanks for taking your time reporting.
