Blender hangs when using masking, dilate-erode and soften node #44871
8 Participants
Reference: blender/blender#44871
OSX 10.10.2, GTX970
Broken:
000dfc0
Worked: 2.74
This is a bit of a weird bug.
Blender hangs when combining the soften node and the dilate erode node together with masking. It only happens if soften and dilate are active, if one of them is muted blender works fine. I suspect the dilate/erode node is problematic in some way anyway, because if i set it to linear feathering, i get these issues in the console: http://www.pasteall.org/58689
I guess the interesting line here is "BLI_assert failed: /Volumes/blender/source/blender/compositor/operations/COM_BlurBaseOperation.cpp:144, make_dist_fac_inverse(), at '0'"
Open this file: linear_feather.blend
Press F12
Tweak the mask rapidly, maybe by moving its center point quickly in small steps around. At some point blender just hangs and has to be killed. No errors in the console, not even with --debug or even using lldp. It's superweird. And: i couldn't reproduce on linux.
Added subscriber: @sebastian_k
Added subscriber: @Blendify
I would try I build from build bot there were some threading issues that were fixed so it's worth a try
https://builder.blender.org/download/
Added subscriber: @jensverwiebe
I tested buildbot, also @jensverwiebe could confirm the issue.
Added subscriber: @Psy-Fi
Meh, Indeed I can't reproduce issue on linux. I'm putting the file through valgrind but it's so sloooooow that I don't think it will be possible to find the issue easily.
nothing under windows
Added subscriber: @mont29
Added subscriber: @ideasman42
Manged to redo the report, with address sanitizers thread checking, see: P228.
@Sergey, you worked most here before heres a proposed fix P229 ...
Posting here incase theres good reason to resolve some other way.
Updated: managed to find another race condition, needs further investigation.
Added subscriber: @Sergey
@ideasman42, didn't see your comment before.. I've run into same report from hellgrind and your patch is correct. Please go ahead and commit it.
@sebastian_k, the assert failure you see is likely caused by the memory corruption. Did you manage to reproduce the hanging blender when running it from lldb? If so, having full threads backtrace will give some clues.
Checked this morning,
Found another race condition, 2 threads are using
LOCK_DRAW_IMAGE
at the same time (initImage
anddraw_image_main
)See stack trace: P230
note, when hanging there are 2 threads in
BLI_lock_thread
, one waiting onLOCK_VIEWER
the other onLOCK_DRAW_IMAGE
. however both threads lockLOCK_DRAW_IMAGE
in their call-stack.@Sergey I was able to reproduce with lldb, but that didn't seem to print anything. Are there any options or arguments I should run Blender with for threads backtrace?
Added subscriber: @sebastian-4
@sebastian-4, you need to type in lldb after the crash:
thread backtrace all
.@ sebastian: use "thread apply all bt"
Jens
Here's a backtrace:
http://www.pasteall.org/58892
Sounds quite similar to what helgrind reports about locking order. Will check tomorrow.
This issue was referenced by
bb5e46f105
45fd68bc98
