SVG object x and y Size bug #44996
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#44996
I'm using the new inkscape (0.91) and blender (2.74) version. In inkscape, I create a rectangle with this sizes: 17m x 20m, no border. Then, I save it as a svg file. Next, I import it in blender: File > Import > SVG.
The problem here is the size of the object. X is 17 (This is correct) and Y is 19.996 (This is not correct).
When I rotate the rectangle 90 degrees in inkscape and save it as a svg file, I have this problem:
X is 20 (This is correct) and Y is 16.997 (This is not correct).
There must be a problem with Y.
Added subscriber: @blenderLight
Added subscriber: @mont29
Please always attache need file(s) (the .svg, here) to help reproducing the issue.
In this case, this is most likely floating precision issues… need file to confirm, though.
Here:
Added subscriber: @ideasman42
Yeah, this looks like classical floating point error… @ideasman42 will let you make final decision here.
I think so, too.
X is correct, but Y not.
Is there a fast solution to fix this?
Closed as duplicate of #45460
