Hard edges don't go away when removed despite disappearance of cyan lines #45101
2 Participants
Reference: blender/blender#45101
Happens on both Windows 10 and Windows 7
2.74
000dfc0
I imported an FBX file that came from Maya which worked fine aside from one small part of it. A certain small piece from the full model contained a part with anomalous shading where I am unable to bridge a flat face and make it appear flat.
After recalculating normals, making the whole mesh have flat shading, and removing edge shading (i.e. setting the mesh to smooth edges) it still occurs. No matter how I try to connect the front face (on both sides, including the one that isn't connected) either with n-gons, quads, or trianges, weird shading occurs.
I then exported this part of the model to an OBJ file, anomaly.obj. Interestingly, when imported into Blender, this OBJ file contains hard edges that weren't in the model I exported.
After again removing the hard edges and setting the whole model to flat shading, the issue still persists like in the first image in this report. This means it's not an issue with the FBX importer because the anomaly is also contained in the OBJ file, or more likely, Blender's handling of it. Now, the model from this OBJ file can be exported to yet another OBJ file and it also contains the hard edges like in the second image in this report.
The issue can be fixed by clicking Clear Custom Split Normals Data under Geometry Data in the Data tab (the one with the triangle icon).
Added subscriber: @Keavon
Added subscriber: @mont29
Well, thanks for the report, but you found the solution yourself - you have to clear custom normals data!
Ideally, clearing sharp edges should recompute/update clnors, but this is true for virtually any operation in Edit mode that affects topology and/or shading. Currently, this is not considered a bug but a known limitation and TODO. Custom normals are therefore only considered working for 'final' mesh, and should be cleared/updated manually in case you edit it.
Thanks for taking a look and thanks for the info on that. However, as a user who doesn't know what all of those technical details mean, the way Blender acts in this edge case is clearly the behavior of a bug, not merely a limitation, so it seems to me that it should be classified as that. If I remove a hard edge, it should either work or tell me it didn't work due to a limitation. If it appears to work, but secretly it doesn't, that's a bug in my book.
