RGBA PNG Stereo 3d Anaglyph renders turn all shades of black into alpha in 2.75 RC1
Broken: Blender 2.75 RC1
Issue:
If you save a Stereo 3D Anaglyph render as a png with RGBA it'll turn all shades of black into alpha.
If rendered as RGB PNG it saves it properly.
HOW TO REPRODUCE:
Render a Stereo 3D Anaglyph version of any scene
Save it as RGBA PNG
All black is now transparent
Errorfound9 (Errorfound9) raised the priority of this task from to 90.
Errorfound9 (Errorfound9) updated the task description. (Show Details)
Errorfound9 (Errorfound9) edited a custom field.
It thinks that the generation of the alpha channel is wrong.
You think that it is expressed black, but this is because it did not set a light when you render it.
with world light
without light
version 2.75 (sub 1), branch b'master', commit date b'2015-06-16' b'23:38', hash b'81b37f5', b'Release'
Even if a light is set when there is an object behind, alpha channels seem to be different.
blender crashes when I load the file which I attached.
I do not understand the cause.
I remade it.
@Dalai Felinto (dfelinto), assigning to you, but Ill check on it too, since we should try resolve before release.
@Campbell Barton (campbellbarton) did you manage to reproduce the issue? I just tested it with the official RC1, and things are fine. (OSX)
