Image Sequence is not reported correctly in `bam deps`
BAM deps doesn't list image sequences correctly (it only lists the initial image, ignoring frame_duration and frame_offset).
Unzip attached file:
//texture-1-2.blend
//node-compo-3-4.blend
//texture-node-5.blend
//sequence/ABC_####_L.jpg (e.g., ABC_0001_L.jpg)
Test either one of the .blend files with:
bam_cli.py deps --json filename
They all list the initial image only (//sequence/ABC_0001_L.jpg), while each one should instead list the ones they are using:
//texture-1-2.blend
//sequence/ABC_0002_L.jpg
//sequence/ABC_0003_L.jpg
//sequence/ABC_0004_L.jpg
//sequence/ABC_0005_L.jpg
Dalai Felinto (dfelinto) set Type to Bug.
Dalai Felinto (dfelinto) created this task.
Dalai Felinto (dfelinto) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) triaged this task as Normal priority.Jun 27 2015, 4:06 PM
Sybren A. Stüvel (sybren) closed this task as Archived.
Sybren A. Stüvel (sybren) claimed this task.
Superseeded by BAT🦇
BAM has been superseded by Blender Asset Tracer (BAT). BAT supports many of the features of BAM, and is actively being developed. All open tasks regarding BAM are closed, and the project will be set to read-only. If you use BAM in your own project, please consider migrating to BAT.
