Select shortest path (for Curves)
Currently with meshes you can use select shortest path.
Ctrl+RMB to select the shortest path between the active vertex and the one under the cursor.
A similar version of this could be added to curves, so you can quickly select segments between 2 vertices.
This is quite simple since its only selecting a range of verts on a curve.
I had a try and followed https://developer.blender.org/diffusion/B/browse/master/source/blender/bmesh/tools/bmesh_path.c;10c1f208b724a87258f4751e01d6bc8a4488a694$96. This might be simplified for curves.
http://www.pasteall.org/59308/diff
Anyway it works for curves and surfaces but it reports memory leaks after closing blender.
I can't figure out how MEM_mallocN works. If I pass sizeof(int) it crashes.
Ran blender with --debug-memory and it turns out that despite the call to BLI_heap_free the heap is not correctly freed.
