Limited bevel causes edges to move incorrectly (2.75 regression)
OS X 10.10.4, AMD 5770
Broken: 2.75 official (and 2.75.2 15c301f)
Worked: 2.74
Using the bevel modifier's limit feature causes some edges to "pop out of place" and move slightly, messing up shading.
See attached bevel_warp.blend file. Play with the limit settings on the bevel modifier, notice how "angle" limit mode causes the mesh to distort. If you view the model from top-ortho and toggle the modifier visibility on and off, you can clearly see it's not a shading artifact and the modifier is actually moving edges when it shouldn't be.
Jason Clarke (jtheninja) raised the priority of this task from to 90.
Jason Clarke (jtheninja) updated the task description. (Show Details)
Jason Clarke (jtheninja) edited a custom field.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.Jul 6 2015, 12:05 PM
Yes, I can see the problem and will work on a fix.
Thanks for the report.
I think this fix should go into a 2.75a release, if possible.
