Closing User Preferences window crashes Blender; triggers "Error: EXCEPTION_ACCESS_VIOLATION" #45422
Reference: blender/blender#45422
Windows 8.1 Pro
i7-4790 CPU @ 3.6GHz
16 GB RAM
GTX 770 2GB
I built this computer myself.
There are two monitors:
Primary: 2550 by 1440, arranged on the right. Connected through DVI to my Graphics Card.
Secondary: 1920 by 1080, arranged on the left. Connected through HDMI to my Graphics Card.
Broken: 2.75a
Worked: N/A
I tried 2.57b to see if the error was present back then. It didn't crash blender when I closed the User Preferences window, but when I later quit Blender, it would crash instead of exiting normally. This crash did not happen without first opening the User Preferences window.
Opening User Preferences from the file menu and then closing it crashes Blender. When I opened it from the command line, I saw "Error: EXCEPTION_ACCESS_VIOLATION" appear at the moment that the close button was clicked. This also occurs if I open a duplicate window with Window->Duplicate Window; closing the new window triggers the same crash and error message.
I open Blender with --factory-startup, and the results are the same. I have also tried both the .zip download, and the installer version, as well as deleting the Blender Foundation folder in Program Files and installing fresh. I also found a [bug report with the same apparent error ]], where someone posted a software OpenGL DLL. It did not fix the issue (but the UI was slow, so I know I used it right). [ https:*developer.blender.org/T42464 | This bug report also appears to document the same issue, though on OSX.
The issue does not occur in a Debian VirtualBox instance, on the same computer. I could also not reproduce the error on a different computer, my MacBook.
Here is my system-info.txt: system-info.txt
Also, this may not be relevant, but when I open Blender from the command line, I get the message "AL lib: (EE) UpdateDeviceParams: Failed to set 44100hz, got 48000hz instead".
Open User Preferences window, close User Preferences window. Error occurs.
Added subscriber: @Zeliss
Oh, and I also tried changing the 3D Viewport to User Preferences (not opening a new window) and changing it back. This did not induce the crash.
Added subscriber: @JacobMerrill-1
I read about this in the game engine section,
delete your imported preferences
Added subscriber: @mont29
Most likely a GPU/driver issue, can you please:
PS: The 'AL lib' line is just info/warning about audio stuff, nothing to worry about really.
No news since one week…
I have no running antivirus.
No luck with the latest build.
No luck with tweaking OpenGL settings in user prefs.
No luck from changing my GPU driver settings.
For posterity: I built a debug release of Blender, attached a debugger, and triggered the crash.
It appears that GHOST_WindowWin32::bringTabletContextToFront uses GetProcAddress to retrieve the ""WTOverlap" function and call it. Somewhere along the line (I don't have symbols for it) this triggers an access violation. When I removed wintab32.dll from my C:\Windows\System32 folder and rebooted, the problem went away, since Blender would no longer load that library and trigger the bad call. Perhaps the call should be wrapped in a try/catch?
I don't fully remember, but I would not be surprised if this problem started immediately after I installed tablet drivers.
