Custom Shape Orientation For Bones Solved #45457
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#45457
orient_custom_shape_V2.py
Added subscriber: @Michael_B
I have been going over a tutorial for Rigging
and there was problem within Blender
for orienting a custom shape for the Bones
at the properties menu on the right side -> Bone -> Display ->
Custom Shape
The problem is described in this you-tube video from 7'40"
and at 11'30" he s showing what needed to be done manually -
translating rotating & scaling even after the script he shows
for every bone in the armature !!!
Blender Character Rigging 9 of 10
https://www.youtube.com/watch?v=miphUq4uwNM
some one wrote in the talk-backs :
most frustrating step -,-
and also check out
http://blender.stackexchange.com/questions/17763/easier-way-to-orient-custom-bone-shapes
Although I am a programmer , I never programmed within Blender
but I wanted to figure it out and I did
and the problem is totally solved with the current add-on that
is attached to this mail - after picking the custom shape -you
only need to click the button
orient custom shape and everything is OK
but it can be better - if the function within the script that
I updated
can be appended just after the pick custom shape script within
Blender
so there will be no need to even click the button
(I also added a check-box and an extract shape button- to
extract the custom shape from the bone if you need to use it
elsewhere
So I just wanted to give the script to you
and hopefully you can pass it on to someone that can append
it to the
Bone -> Display -> Pick Custom Shape script
Thanks
Michael B
Removed subscriber: @Michael_B
Added subscriber: @Sergey
Added subscriber: @aravergar
When orienting custom shape deleting the original custom shape, a corrupted version of the shape keeps behind, even after removing the whole armature. This corrupted version can be seen in Blender Files display mode in the Outliner. It can't be erased nor selected.
Added subscriber: @BrendonMurphy
Any resolution here, is this valid?
no activity, archiving
feel free to submit a new task if the addon is currently working & valid
