New viewport: modifier+matcap+edit mode = mess
Mac OS X 10.10.4, AMD 5770
Broken: 4093630
A mesh with certain modifiers (construction ones that draw in edit mode, such as mirror, bevel, array, etc) will draw corrupt when in edit mode with matcaps enabled. Disabling matcaps, going into object mode, or hiding/removing the modifier will remove the issue
The attached .blend contains some mirrored cubes and has matcaps turned on. Load it up and enter edit mode, observe mess.
Commits
rBc23d29c58e8c: Fix T45465
Jason Clarke (jtheninja) updated the task description. (Show Details)
Jason Clarke (jtheninja) raised the priority of this task from to Needs Triage by Developer.
Jason Clarke (jtheninja) set Type to Bug.
Bastien Montagne (mont29) triaged this task as Confirmed, Medium priority.Jul 17 2015, 12:51 PM
Issue confirmed, @Campbell Barton (campbellbarton), @Antony Riakiotakis (psy-fi), think this is in your area?
Also, 2.75a does not show the issue.
Nice catch, let me check it out
