shader node tree driver
Win7x64 GTX660M
Broken: old dependency graph == not supported
Worked: partially working in new depsgraph using build '1b8e0d0'
examine provided blend file
single property driver inside shader node tree is missing update when source property change
--enable-new-depsgraph
  1. open blend file and change ParticleSystem count number
  2. the driven value in shader node tree is not updated
  3. 'touch' (try to move/change value in driver node value) to invoke update
Czarek Kopias (kopias) set Type to Bug.
Czarek Kopias (kopias) created this task.
Czarek Kopias (kopias) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) closed this task as Archived.
Thanks for the report, but this still known TODO and not considered a bug currently.
