voxel data (.raw) not displayed because of startup.blend
Closed, InvalidPublic
OS: windows 8.1 64bit
GPU: NVIDIA GTX 860m
Broken: official 2.75a
my custom startup.blend breaks the display of voxel data (raw) for some reason. sorry i could not find the setting that causes this so it would be great if someone with more knowledge could take a look why this is not working.
blend:
with default startup.blend:
with attached startup.blend:
raw data
the resolution of the raw data set is (385, 267, 405)
  1. load the startup.blend
  2. switch to the textures tab
  3. change the voxel data source path to the raw data that is attached above
  4. adjust the resolution to (385, 267, 405)
  5. notice its just black
  6. remove the startup.blend so the factory settings are loaded and repeat step 1-4
  7. notice this time the data shows up
dan grauer (kromar) set Type to Bug.
dan grauer (kromar) created this task.
dan grauer (kromar) raised the priority of this task from to Needs Triage by Developer.
this can probably be closed since it was "user error" the frame was set to 0 where its assumed that its a image sequence or something like that setting the frame to 1 or enabling "still frame" and setting still frame to 1 solves this problem.
however it would be nice if the user would get a hint when his frame is set to 0
Julian Eisel (Severin) closed this task as Invalid.
Julian Eisel (Severin) claimed this task.
Closing since issue was on user side. Thanks for the report nevertheless.
