Mask and PNG #45622
2 Participants
Reference: blender/blender#45622
When render in the compositor the node "Matte_Keying" and output to PNG RGBA, only Alfa pixels are write "1", but the previous values of RGB color of the pixels with alpha 0 remains , that means that the weight of the image is still large, the pixel information with alpha=0 should also be unified to black for PNG compression to take effect
see images:
The same image
458 k
8 M!!!!
nodes:
Added subscriber: @ciriaco
This comment was removed by @ciriaco
If you open the two images in the composer without applying transparency "use alpha" will see that the image of 8M still has the RGB information in the transparent pixels
Blender output render image (PNG, RGBA, 5% compression ratio): 8 M !!!!
Open the image 8 M in gimp, and save again but this time with the option
"not save values on transparent pixels" and 10% compression ratio, the image now weighs 458 K
Gimp saved 458 k
Added subscriber: @Sergey
That is a wrong assumption that channels with zero alpha should be black. PNG is a straight alpha as per standard and blender follows that. You can still force transparent pixels to be black in compositor tho, so wouldn't consider it a bug.
Thanks for the report anyway.
Hello, I think it's a bug Because if I try to make transparent pixels RGB value to black, also recording RGB information and no compress, the image is still weighing 8 M
I think that there should be an option in the PNG output to not record RGB values in the transparent pixels as in gimp. This is important to save memory in long productions
http://thesecondmanproductions.blogspot.com.es/
https://www.youtube.com/watch?v=FAC4m11p4KI
Thanks for your work
There is no such thing as "not record RGB values in the transparent pixels", all the pixels do exist in the file.
Also i can't confirm here that making RGB channels black for alpha=0 doesn't help. It sames like 4x of the image size. It's hard to compare it with the result of gimp you're having because your 8meg file and 400kb files are made from different frames.
Here's an example of how you can do the trick for RGB colors: png.blend
Hi,
"There is no such thing as "not record RGB values in the transparent pixels", all the pixels do exist in the file."
in gimp yes:
Thanks for the example !!
A bit complicated for artist... not very intuitive.
I think is better the solution of gimp... press a buton "not save the RGB values in trasparent pixels"
"Also i can't confirm here that making RGB channels black for alpha=0 doesn't help. "
Hi, I think that yes it helps, because the PNG compressor groups all the same RGB value pixels in an indexed list. The important thing is that transparent pixels have the same RGB value (black or color you want) then compression acts.
I researched a bit and I made a comparative test:
Base frame 8 M:
Saved : PNG RGBA, 15% compression, pixels alfa=0 with RGB initial values = 2,8 MB
Saved : PNG RGBA, 15% compression, pixels alfa=0, with RGB= black= 1,6 MB
With transparent pixels normalized to black: aprox -40% storage use
PNG's compression exploits color similarity across the Y axis of the image, so surely increasing this similarity (by setting colors to black) improves compression and reduces overall file size.
It would be nice to have a tool to make operation of setting transparent pixels to black, but it's out of the scope of the bug tracker.
Thanks for your reply, yes, it would be interesting to develop this tool Because it would help the films production in blender. = :-)
Sorry for the noise in the channel
