Standalone game engine won't start #45679
7 Participants
Reference: blender/blender#45679
Broken: 2.75a and 2.74
Worked: any earlier
I click standalone engine button and only thing that happens is prompt window will fill with text (as shown in the picure{F219419}) but this only happens when there is material in the scene. With uncoloured cube it won't happen. But as soon as I add the first material to the game I will never see the standalone engine again. Not even when the material is deleted.
Added subscriber: @LittleScoty
Added subscriber: @Blendify
Added subscriber: @JorgeBernalMartinez
I can not reproduce the bug. Windows 7 64bit & blender 2.75a
Any sugestion what it could be caused by?
Added subscriber: @Sergey
Please attach .blend and all other files (textures?) which are needed to reproduce the bug.
rainbow_run.blend <- this is one of many that won't start, however I tried to revert blender to factory settings and now the standalone engine starts but only when scene remains more or less unchanged
one texutered starting cube - engine runs
more simple obbjects (not even using materials or textures or anything) - engine won't run
Added subscriber: @hg1
Actually there is no Blender bug.
If you look at the output you will see that are two textures are missing in your file.
You have enabled "Automatically Pack Into .blend". If you have enabled it Blender tries to pack the files into the temporary output .blend file.
If are files missing Blender will now generate an error.
So add the missing textures to the project or disable "Automatically Pack Into .blend" and start the standalone player without the missing textures.
backup.blend - friends file, no textures missing, same problem
Also why is previous file running at another computer where are textures also missing?
Also, why are they missing? I'm pretty sure the whole file was created on 1 pc, using my standart default file for games where packing is checked
This file is working for me without problems. (The clipping fault is caused by the activated Transparency.)
Actually I don't know. Maybe the file was loaded without UI, or in the Blender user preferences is something different. Or the files are existing on this PC.
If previous packing (other Blender version, other PC, or something else) was deactivated and you deleted, moved or renamed the textures in the file explorer, Blender will not find these files any more. You have to assign it again.
Thank you for your help, although it wasn't realy helpful. Standalone engine is simply not running.
So 1 last question. If .blend file has issues running in standalone... Will it run after my project is exported to standalone game?
The blend file will start if you start with the blenderplayer. But if are files missing and you have enabled autopacking the exporter will generate the same error on extorting.
I repacked the two Images with the wrong path and replaced Numbers.png with Numbers_red.png on the UV mapping.
rainbow_run.blend
Try this file, if it isn ot working then try to deinstall Blender delete the old settings C:\Users<your user name>\AppData\Roaming\Blender Foundation\Blender\2.75 and install blender again.
AppData is invisible if you not have changed the explorer settings, So change the Explorer strings or copy and pate the path and type in your user name. Or type in \AppData after you have chosen the user name in the Explorer.
This will cost me some time but seriously thank you for your help.
(Btw. what can I do with the material clipping? Internet doesn't seem to help very much)
Removed subscriber: @Blendify
Added subscriber: @mont29
Added subscriber: @panzergame
@LittleScoty : Did you find a solution ?
No
This task is being closed because the BGE has been removed in Blender 2.8.
