fast navigate is bugged if you are zooming with mousewheel
Closed, InvalidPublic
win32
Broken: since fast navigate is in Blender sculpt mode
Worked: never
When you have Fast Navigate enabled, zooming in/out with the mousewheel does not trigger it.
To reproduce :
  • File -> Load Factory Settings
  • With the default cube, go to Sculpt Mode, add a Multires modifier
  • Go to Sculpt mode , add a Multiresolution modifier and click Subdivide 2 times
  • In the sculpt mode toolshelf, click on Options tab and enabled Fast Navigate.
  • With your middle mouse button, rotating the view left/right correctly trigger the Fast Navigate as the model revert to the level 1 multires during the process
  • Zoom in/out with mousewheel and you will notice that the model does NOT revert to the level 1 multires
  • Go to File -> User Preferences -> Input panel
  • Enable "Emulate 3 mouse button"
  • Back to sculpt mode, instead of zooming in/out with mousewheel, hold ALT and CTRL and Left Mouse button , move the mouse to zoom
  • You will notice that during your zooming process the model correctly revert to level 1 multires
Blend ready to use to fasten the test :
Load with "Load UI" enabled
Just zoom in/out with mousewheel, to see Fast Navigate doing nothing
Then zoom instead with holding CTRL+ALT+LMB to see Fast Navigate working
Sanc Tuary (sanctuary) set Type to Bug.
Sanc Tuary (sanctuary) created this task.
Sanc Tuary (sanctuary) raised the priority of this task from to Needs Triage by Developer.
Psy-Fi mentionned on the BA board :
http://blenderartists.org/forum/showthread.php?264568-Dyntopo-tests&p=2915317&viewfull=1#post2915317
"Hmm...well, the problem is that this is not a bug. Each mouse wheel step is a separate instantaneous operator, and fast navigate happens only for modal operators."
So not a bug, just a limitation of Fast Navigate, i guess this report can be closed
