Particle system of descendant of transformed proxy causes proxy to lose transformation, reverting to it's source's transformation #45690
Reference: blender/blender#45690
Given a proxy of an object with a transformation. Given a particle system attached to an object that is a descendant of said proxy. The root proxy is displaced as in the object "gun_2_src_arma_proxy" in tester_consumer. On emission of particle, the entire proxy hierarchy is displaced back to the source position on particle emmision.
It is irrelevant if the type of particle system (proxy,linked,etc). Any particle system attached to a descendant of a displaced proxy causes the displacement applied to proxy to no longer apply.
This is very annoying and renders the workflow I am attempting to create linkable objects an impossiblity without resorting to possibly:
I haven't tested said workaround.
Note: This is a critical bug that cannot wait for a comprehensive refactoring of the particle system as it makes the creation of duplicated objects as intended by the workflow delineated in these test files quite impossible.
Added subscriber: @dlots
https://developer.blender.org/F220375
https://developer.blender.org/F220377
The workaround is to create a child of constraint on a particle system. Regardless, I believe this should be maintained as a bug and fixed regardless of any possibility of a particle system rewrite.
Added subscribers: @LukasTonne, @brecht, @JulianEisel
Yep, something weird going on here. @LukasTonne, @brecht, what do you think? Is this fixable without causing more trouble?
Steps to reproduce: Open tester_consumer.blend, play animation
If this is a bug and it's not fixed, then not because we don't want to or so. The issue with particles is that fixing one bug causes multiple other ones. Particles are broken and need a rewrite.
Known bug, particles emission can only handle direct parent object relations for emission interpolation via ugly hack.
Removed subscriber: @LukasTonne
Closing as limitation then. @dlots, we're all not happy about the current situation, but we can't do much without a particle rewrite.
