Shortcut to confirm "Ok" with keystroke "o" in 'Unwrap (u) -> "follow active quad" (f) -> ok (o)' was removed
Win 7 GTX 970
Broken: 2.75 official release (1.7.2015)
Worked: 2.74 official release
When uwrapping objects, i heavily use shortcuts. To unwrap using "follow active quad" i just press "u f o". Easy to remember and very fast, no mouse needed.
The "o" of "u f o" doesnt work anymore, you can not confirm the unwraping options anymore.
Visually the "O" of "Ok" is not underlined as it was in the previous version, therefore indicating, that you can not press a key anymore to select it.
Select a face of the standart cube.
Press "u" to open the unwrap menu.
Press "f" to select the "follow active quad" option
to confirm the settings, you have to confirm now with the mouse, click on "Ok". Earlier you just hit "o".
Lino Thomas (linolafett) raised the priority of this task from to 90.
Lino Thomas (linolafett) updated the task description. (Show Details)
Lino Thomas (linolafett) edited a custom field.
does "u f <Enter>" not work for you? that works here on Arch Linux using 2.75a.
"u f enter" works, but is way slower to type than "u f o", therefore i do not use this combination.
My "u f o" is gone and i would like to have it back ;)
