Blender crashes when creating Environment Map textures in Multi-View mode #45715
5 Participants
Reference: blender/blender#45715
Linux openSUSE 13.2 x64, ATI Radeon 6870, MESA 10.3.7.
Broken: 2.75a
Worked: Unknown
Blender crashes when using multi-view (stereoscopic rendering) if an environment map texture is also being produced. The crash happens during the "Creating Environment maps" stage before rendering begins.
1 - Create a texture of type Environment Map. Set it to Animated, Mapping to Cube, and Viewport Object to the camera. Make sure Shading - Environment Map is also enabled in the Render panel.
2 - Enable Render Layers - Views to turn on stereoscopic rendering (the viewport should become anaglyph).
3 - Press F12 to render and produce the crash.
Added subscriber: @MirceaKitsune
Added subscriber: @tyoc213
Added subscriber: @Blendify
Please post a .blend file that shows the issue
The issue is so quick to reproduce, I figured one wouldn't be needed. But here it is: Simply press F12 and Blender should crash.
http://www.pasteall.org/blend/37469
Post .blend here untitled.blend
This issue was referenced by
e96e0ddbee
The environment map is being rendered once per view. This is not ideal. But at least it doesn't crash now. Let me know if it works as expected.
That should not be a huge problem, and it's probably the only working solution to begin with. First of all because you'd get double stereoscopy if both the 3D surface and envmap texture are stereoscopic, and envmaps are typically cubes so things like eye convergence are probably not applicable. I don't have Blender set up to compile here, so I'll try the fix once 2.75b or 2.76 are out. Thank you for solving this.
You can try a build from builder.blender.org
