baked texture not updating in viewport after using undo #45788
Closed
opened 2015-08-13 17:01:14 +02:00 by Daniel Grauer · 8 comments
Member
OS: windows 7&10 64bit
GPU: NVIDIA quadro k4000, gtx 860m
Broken: 2.75.2 0b7d0f9 & 2.75.4
using undo after baking a texture to a object and then using undo will break the viewport update of the texture. its still baked in the uv editor but im not able to get it to update in the viewport any more unless i restart blender.
  1. open blend file textureBakeViewportUpdate2.blend
  2. select all objects (a) and bake textures. after that you should see textures on all the objects
  {F223963}{F223965}
  1. there is a script which bakes when moving the planes, makes it a bit easier to reproduce. open a text editor and run the continuousBake.py script
import bpy
class Observer:
    def __init__(self):
        self.last_location = (0,0,0)
    def print_updated_objects(self, scene):
        updated_objects = []
        for o in scene.objects:
            if o.is_updated:
                updated_objects.append(o)
        if(len(updated_objects) > 0):
            if not (updated_objects[0].location == self.last_location):
                self.last_location = updated_objects[0].location.copy()
                bpy.ops.object.bake_image()
                print("updated objects: %s"%updated_objects[0].location)
            else:
                print("same location")
bpy.app.handlers.scene_update_post.append(Observer().print_updated_objects)
  1. now move the plane with the name "Plane" and notice how the texture gets baked when you move it
  2. select the plane with the name "refPlaneZ" and hide it
  3. move the plane with the name "Plane" again
  4. use undo to unhide the plane with the name "refPlaneZ"
  5. notice the plane "Plane" will turn white and none of the planes will update the texture when you move them
  {F223968}
  1. open a uv editor and move a plane, notice that the texture in the uv editor is still baked so i assume there is something going wrong when updating the texture in the viewport
  {F223970}
**System Information** OS: windows 7&10 64bit GPU: NVIDIA quadro k4000, gtx 860m **Blender Version** Broken: 2.75.2 0b7d0f9 & 2.75.4 Worked: (optional) **Short description of error** using undo after baking a texture to a object and then using undo will break the viewport update of the texture. its still baked in the uv editor but im not able to get it to update in the viewport any more unless i restart blender. **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps 1. open blend file [textureBakeViewportUpdate2.blend](https://archive.blender.org/developer/F223962/textureBakeViewportUpdate2.blend) 2. select all objects (a) and bake textures. after that you should see textures on all the objects ``` {F223963}{F223965} ``` 3. there is a script which bakes when moving the planes, makes it a bit easier to reproduce. open a text editor and run the continuousBake.py script ``` import bpy class Observer: def __init__(self): self.last_location = (0,0,0) def print_updated_objects(self, scene): updated_objects = [] for o in scene.objects: if o.is_updated: updated_objects.append(o) if(len(updated_objects) > 0): if not (updated_objects[0].location == self.last_location): self.last_location = updated_objects[0].location.copy() bpy.ops.object.bake_image() print("updated objects: %s"%updated_objects[0].location) else: print("same location") bpy.app.handlers.scene_update_post.append(Observer().print_updated_objects) ``` 4. now move the plane with the name "Plane" and notice how the texture gets baked when you move it 5. select the plane with the name "refPlaneZ" and hide it 6. move the plane with the name "Plane" again 7. use undo to unhide the plane with the name "refPlaneZ" 8. notice the plane "Plane" will turn white and none of the planes will update the texture when you move them ``` {F223968} ``` 9. open a uv editor and move a plane, notice that the texture in the uv editor is still baked so i assume there is something going wrong when updating the texture in the viewport ``` {F223970}
Author
Member
Author
Member
Added subscriber: @DanielGrauer
Added subscriber: @Sergey
My guess is that this is related on the GPU object restore policy in the undo file loading. Not sure there's a clean way resolving this, it's kind of stretching the system to it's max.. But needs some closer look.
Added subscriber: @ideasman42
Campbell Barton self-assigned this 2015-08-24 13:04:25 +02:00
Images have their own undo system which works for paint, but not for bake.
This is more of a TODO relating to the undo system.
http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Undo.2C_Redo_and_Operator_Context
Images have their own undo system which works for paint, but not for bake. This is more of a TODO relating to the undo system. http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Undo.2C_Redo_and_Operator_Context
Author
Member
is there some timeline when these issues will get worked on? or maybe something we could contribute to get this fixed?
Reference: blender/blender#45788
