.3ds import: mesh position is not correct. #45866
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#45866
You can try downloading the files in the sample sites. 3ds format
http://www.bnos.com/en,obiekty-3d,46,1.html
Broken: (example: 2.69.7 4b206af, see splash screen)
Added subscriber: @gramax
Added subscriber: @mont29
Assuming we are still maintaining this addon, thinks it’s for you Campbell. Looks like some issue in parenting transforms…
mesh position is not correct. object does not occur rightto .3ds import: mesh position is not correct.Added subscriber: @BrendonMurphy
hi, this is a longstanding issue with .3ds import. I have tested 100's of models from many sites. The success ratio was around 50% of .3ds files have the wrong position, most of these files were from older archive model sites. That said I have also tested the same files in hexagon with mixed results. Some of the failing files imported very well, others still had "artifacts/wrong position". It may be that older .3ds files fail & newer .3ds are ok, but I cannot be sure on that.
I would like to see this fixed but afaik it's been a problem for years & not entirely blenders fault.
Thanks.
Added subscriber: @blend-it
confirm randomic problem.
all my 3ds are from max/viz 3 (very old version!) but some models are imported well, and some are wrong.
As this issue is known problem for years & no action has been taken nor is likely to be taken this task is being archived.
