Viewport material mode broken
Closed, DuplicatePublic
WIN 7
Nvidia GTX 460
Broken: 58c9a0b
Worked: 709a31d
Basically the image talks by ti self, in material mode the vieport shows unselected objects as black and selected full yellow or orange depending if it is the active object or not.
1-set the render engine to blender internal
2-set the viewport shadeing to material mode.
Nahuel Belich (belich) set Type to Bug.
Nahuel Belich (belich) created this task.
Nahuel Belich (belich) raised the priority of this task from to Needs Triage by Developer.
Yeah it happen to me also, I can't view my texture in texture shade mode or material shade mode or even in rendered mode for blender internal.
I'm on linux 64 and here's my graphics specification:
renderer: 'GeForce GT 635M/PCIe/SSE2'
version: '4.5.0 NVIDIA 355.06'
Blender 2.75a StableBlender Master Branch 2672ee7
here's the error message in terminal :
GPUShader: compile error:
0(3) : warning C7547: extension GL_EXT_geometry_shader4 not supported in profile gp5fp
0(152) : warning C7533: global variable gl_ProjectionMatrix is deprecated after version 120
0(1286) : warning C7533: global variable gl_ModelViewMatrix is deprecated after version 120
0(1287) : warning C7533: global variable gl_ModelViewMatrixInverse is deprecated after version 120
0(1383) : error C7531: global function textureQueryLOD requires "#extension GL_ARB_texture_query_lod : enable" before use
0(1383) : error C0000: ... or #extension GL_EXT_gpu_shader4_1 : enable
0(1383) : error C0000: ... or #extension GL_NV_gpu_shader5 : enable
0(1536) : warning C7533: global variable gl_NormalMatrix is deprecated after version 120
0(2045) : warning C7533: global function shadow2DProj is deprecated after version 120
0(2196) : warning C7533: global variable gl_LightSource is deprecated after version 120
0(2196) : warning C7533: global variable position is deprecated after version 120
0(2197) : warning C7533: global variable diffuse is deprecated after version 120
0(2214) : warning C7533: global variable halfVector is deprecated after version 120
0(2216) : warning C7533: global variable specular is deprecated after version 120
0(2293) : warning C7533: global variable gl_ProjectionMatrixInverse is deprecated after version 120
0(2629) : warning C7555: 'varying' is deprecated, use 'in/out' instead
0(2637) : warning C7555: 'varying' is deprecated, use 'in/out' instead
0(2676) : warning C7533: global variable gl_FragColor is deprecated after version 120
i didn't realized but yes i got the same on the consol
https://www.youtube.com/watch?v=1IxKx--qzc0&feature
