Sphinx HTML build error. #45908
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#45908
I have been trying to set up everything needed to edit the Blender manual and I have run into a snag in the last step, building the HTML files .
When I run
I get
And there is no folder called build in my blenderDocs folder.
I put the folder on my desktop, not directly under
C:\
as the example suggests, but that shouldn't affect it right?I am also not the only person having this problem, see this mailing list post.
Added subscriber: @PeterGutfeldt
Added subscriber: @GiantCowFIlms
Encountering this issue too:
http://lists.blender.org/pipermail/bf-docboard/2015-August/004888.html
Added subscriber: @gandalf3
Added subscriber: @ideasman42
This is a known issue, and its possible to resolve.
See: https://github.com/sphinx-doc/sphinx/issues/1976#issuecomment-134800310
See:
Could you check if this resolves the issue?
Archiving this ticket, since its a known problem with Sphinx, and theres a solution.
