bevel error #45919
6 Participants
Reference: blender/blender#45919
win 8.1
gtx 750ti
In recent build bot builds I am getting bad result with the bevel tool around edge loops, not matching at the end.
More verts seems to increase the chance of it happening.
The
c150645
build seemed ok.Changed status to: 'Open'
Added subscriber: @daveh
Added subscriber: @Sergey
Please always provide .blend and exact steps needed to reproduce the issue. So far i can not confirm the issue with own tests.
Added subscriber: @Blendify
Sorry, I should have given a more thorough explanation.
I simply added a circle.
Increased the verts to 64.
Extruded up, and filled with ngon.
Then bevel.
It seems to be forming a spiral, rather than a chamfer.
I can confirm. For reference, here is a model built according to Dave's instructions:
bevspiral.blend
I did recently put some limits on a 'width adjustment' pass, which tries to deal with conflicting bevel requirements from adjacent vertices. This was to fix a problem where the bevel width grew hugely when there was a very long chain of edges. I would have thought no adjustment would be needed in this case, but clearly I am wrong. I will investigate. Thanks for the report.
Added subscriber: @tompov
I can confirm this.
It appeared between
24e56d4
and58c9a0b
Perhaps with
c1c07b6
?Tom
P.S., What I had intended was that one could get the old unrestricted width adjustment path by turning on the 'clamp overlap' option, and indeed that does make for an even bevel here. The problem is that the clamp stops the beveling at a fairly small value and I don't understand why (well, I have a suspicion). Will have to also investigate that.
Added subscriber: @howardt
Thanks Tom for suggesting the possible cause of the problem. That is indeed the change that is causing the problem.
Campbell, your change to make epsilon tests in isect_line_line_v3 is testing against too large an epsilon, I think.
In the case tickled here, the V1, V2, V2, V4 args are:
(-0.881921,0.471397,2.432115) (-0.932373,0.387223,2.432115) (-0.791522,0.428641,2.432115) (-0.833481,0.339928,2.432115)
which leads to these values for a, b, ab, and div in the isect_line_line_v3 code:
a=(-0.050452,-0.084174,0.000000) b=(-0.041958,-0.088713,0.000000) ab=(0.000000,0.000000,0.000944) div=0.000001
These are not collinear lines -- they have a 5.625 degree angle between them. Yet the test of div against the default epsilon in the lib calls them collinear. This is all kind of tricky, because we shouldn't be testing against absolute epsilons, since that makes modeling at a small scale hard. One suggested change is to use epsilon * epsilon as the thing to test against instead of epsilon, since the thing it is testing is the square of a length. Making that change fixes this bug, but thought I'd let you decide what to do here.
Of course I could explicitly pass in a much smaller epsilon from the bevel code, but this seems like a problem in the library that should be fixed there.
Reverted the part of
c1c07b68b8
which caused the problemApplied an alternative fix to
isect_tri_tri_epsilon_v3
,since using line-intersections wasn't very stable.
see
6a53e658d3
)Thanks, Campbell.
I confirm that this fixes the bevel problem that was the initial subject of this bug report, so agree that the issue is Resolved.
