"Show weights" in edit mode not always are shown
OS: Windows 10 X64
GPU: Intel Baytrail
Broken: Official 2.75a
Worked: Official 2.74
Blender 2.74
Solid mode
Blender 2.75a
Solid mode
Matcap
Wireframe
Weight Paint
Oscar (KINjO) added a project: BF Blender.
Oscar (KINjO) set Type to Bug.
Oscar (KINjO) added a subscriber: Oscar (KINjO).
Oscar (KINjO) created this task.
Oscar (KINjO) raised the priority of this task from to Needs Triage by Developer.
Blend file
Sergey Sharybin (sergey) triaged this task as Needs Information from User priority.
Can you describe in more details which exact configuration is different between 2.74 and 2.75a?
Bastien Montagne (mont29) raised the priority of this task from Needs Information from User to Confirmed, Medium.
@Sergey Sharybin (sergey) just switch cube to Edit mode, it’s supposed to show weights with this option set, works in 2.74 but not in current master… Probably some regression in drawing code (or maybe derivedmesh evaluation).
Both versions are reset to defaults if that's what you mean.
In the first image (2.74 in solid mode) the weight visualization is ok, however in the second image (2.75a in solid mode) the weight visualization is not working at all.
In the third image (2.75a matcap) there is a slightly color overlay showing the weights, i think that is correct because 2.74 with matcap presents the same behavior.
The problem only happens in 2.75 when the viewport is set to solid mode.
Thanks for your help! :)
Meeeh… Forgot 3DView drawing has changed quite a bit… :/
@Antony Riakiotakis (psy-fi) does this ring some bells for you? reading code, it looks like weight paint (aka CD_PREVIEW_MLOOPCOL) drawing takes two different paths, depending on whether we have an EditMesh DM or not - but both cases are broken currently (nothing happens with an EditMesh DM, and with regular CDDM & co, faces are drawn all yellow-ish, selection color)…
I can confirm the issue here let me check it out
