Limit Scale does not Limit Scale on the Minimum Value
Hello !
Windows 7 Nvidia GTX780
blender 2.75 and NEW DEPENDENCY GRAPH
When you add a limit scale constraint from 0 to 1, the scale is from -1 to 1.
Limit location works well.
Add a cube
Add a limit scale constraint from 0 to 1
Scale under 0 value
Thanks !!
dono dono (dono) added a project: BF Blender.
dono dono (dono) set Type to Bug.
dono dono (dono) added a subscriber: dono dono (dono).
dono dono (dono) created this task.
dono dono (dono) raised the priority of this task from to Needs Triage by Developer.
Bastien Montagne (mont29) closed this task as Archived.
Thanks for the report, but this is known limitation of our current constraint system - it only has access to matrices, from which you cannot correctly extract negative scaling. So it only checks for absolute scale values.
It is a little weird to use but thanks for answer !
