Edge/Vert Slide fail to properly "redo"
Open, Confirmed, MediumPublic
Currently vertex & edge-slide use the mouse input to calculate which edge to slide, the direction to slide, and the Even toggle is set at runtime.
Using operator redo is not re-running with the same options, so redoing the action fails.
We could simply disable redo with this operator, however being able to toggle Correct UV is important.
Adding this report to merge in duplicates, since there are various reports on this, which all have the same root-cause.
