Some bugs on Create Orientation operator
Closed, DuplicatePublic
win8.1 64bit | GTX680
Broken: 2.69 - 2.75a (so far)
I think there are some very strange behavior on the Create Orienation operator, though different between Object and Edit mode.
  • Problem in Object Mode:
Select an object, then click the "+" button on Transform Orientation panel located in N sidebar. when uncheck the "Use after creation" button in F6 panel, the new created one is still used.
  • Problems in Edit Mode:
  1. Same as above.
  1. Select a element then click the "+" button on Transform Orientation panel. Then try to name it, then rename it. you will see the renaming work will cause a duplication. What's more worse is that toggling any of the other three buttons below will also duplicate the existing one, and rename it like *.001,, *.002....
Btw... perhaps it would be better to capitalize the "Use after creation" as "Use After Creation", and "Overwrite previous" as "Overwrite Previous"? (not critical though...)
Thanks for checking.
Leon Cheung (leon_cheung) raised the priority of this task from to 90.
Leon Cheung (leon_cheung) updated the task description. (Show Details)
Leon Cheung (leon_cheung) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Sep 4 2015, 9:48 AM
All those issues have the same root - undo/redo stack vs. UI.
Typically, when doing undo/redo, we do not alter UI/tools settings, since those are not data. Here it seems transform spaces themselves are handled in 'Globla undo' stack, but not by the Edit mode stack - and the selected TS (which is 3DView editor setting) is totally ignored by undo…
Think this is more known limitation/TODO than really a bug, @Campbell Barton (campbellbarton), @Sergey Sharybin (sergey)?
This is definitively not easily fixable, it’s yet another weakness of our undo stack, and will need some re-design to be addressed. Thanks for the report, closing it for now (added a TODO note about it - we already had quite a similar report actually, see T42468).
