baking diffuse color doesn't work properly with uv project #46085
Closed
opened 2015-09-11 20:29:58 +02:00 by mathieu menuet · 9 comments
Win7 x64, R9 280X, Catalyst 15.7.1
Broken: c26a9ee
The baked image color is wrong with uv project. It seems the bake takes the modified UV (from UV Project modifier) also the selected image for the bake is set on "Generated" and not UV. So it should bake the full plane but doesn't. Note that UV Project also gives some artifacts. bug cycles bake uv project.JPG
Open attached file: bug_bake_and_uv_project.blend
you can go to viewport render mode to see what it should look like
click on bake: you get a full white image instead of the projection.
**System Information** Win7 x64, R9 280X, Catalyst 15.7.1 **Blender Version** Broken: c26a9ee **Short description of error** The baked image color is wrong with uv project. It seems the bake takes the modified UV (from UV Project modifier) also the selected image for the bake is set on "Generated" and not UV. So it should bake the full plane but doesn't. Note that UV Project also gives some artifacts. ![bug cycles bake uv project.JPG](https://archive.blender.org/developer/F232295/bug_cycles_bake_uv_project.JPG) **Exact steps for others to reproduce the error** Open attached file: [bug_bake_and_uv_project.blend](https://archive.blender.org/developer/F232294/bug_bake_and_uv_project.blend) you can go to viewport render mode to see what it should look like click on bake: you get a full white image instead of the projection.
Author
Author
Added subscriber: @bliblubli
Author
new versions of the files (corrected):
new versions of the files (corrected): [bug_bake_and_uv_project.blend](https://archive.blender.org/developer/F232303/bug_bake_and_uv_project.blend) ![bug cycles bake uv project v2.JPG](https://archive.blender.org/developer/F232304/bug_cycles_bake_uv_project_v2.JPG)
Added subscriber: @Sergey
Cam confirm the issue. Wondering if it's caused by Clip extension mode. Will need to have a closer look.
This issue was referenced by d7ceca8c93
This issue was referenced by d7ceca8c934d098832191d6ae6bd2b08dd552d89
Added subscriber: @brecht
Plugging generated coordinates into the image texture node does nothing, baking is only supported for UV coordinates. You can use a second UV map instead of generated coordinates.
The artifacts in the render and baking are due to poor UV project coordinates for vertices behind the camera, that I've fixed.
Plugging generated coordinates into the image texture node does nothing, baking is only supported for UV coordinates. You can use a second UV map instead of generated coordinates. The artifacts in the render and baking are due to poor UV project coordinates for vertices behind the camera, that I've fixed.
Reference: blender/blender#46085
