Action Actuator - Flipper Mode Frame Glitches #46122
7 Participants
Reference: blender/blender#46122
flipper_ani_bug.blend
win7 64bit
Broken:
2.75 buildbot from 15.9.2015
2.75a official
2.74 official
Worked:
no exact clue - it worked definitly in 2.49b
there have been some Bugreport for this exact topic in Blender 2.71 too - these where solved back then
Frame Glitches in Action Actuator - Flipper Mode
Start and End-Frame sometimes stops 1 frame too early at start - or to late at end
****BAD WORKAROUND
on the left "flipper" object (use left CTRL key) i do a bad workaround in the Action-Actuator
i set the Start-Frame -1 (to frame 0 istead of 1)
and the End-Frame +1 (to frame 9 instead of 8)
this will fix the glitch but will introduce a not precise animation / reaction
****NOTES
this occurs independent of "animation framerate" setting - wich is set to 60 in this case
thank you and have a good day, Tobi
Added subscriber: @blenderhilfe
BGE - Action Actuator - Flipper Mode Frame Glitchesto Action Actuator - Flipper Mode Frame GlitchesAdded subscriber: @Blendify
Added subscriber: @Sergey
Added subscribers: @hg1, @dfelinto, @Moguri, @brita, @dr.sybren, @panzergame
I did some digging, and it worked fine in 2.70a, but was broken in 2.71. It may have something to do with the patch for #41168. If the action is fully played, and then the trigger removed (in this case, you release the RCTRL key), it should play back to the first frame. However, it doesn't update the object, even though
BL_Action::Update(float curtime)
andBL_Action::UpdateIPOs(float curtime)
are called with the correctcurtime
.@blenderhilfe: The glitch is fixed in
728d1ec504
.@dr.sybren: I confirm for the flipper action not backed, but it's not the subject of this task. We should change it for this bug or close it ?
Added subscriber: @JorgeBernalMartinez
Hi @panzergame,
See #46728 seems related to this issue.
I don't know what you mean with "the flipper action not backed", but I think things should just work. If you can, just fix the bug you found :)
Added subscriber: @JacobMerrill-1
@panzergame do you have a patch for upbge that may be applied here?
Removed subscriber: @Blendify
This task is being closed because the BGE has been removed in Blender 2.8.
