Incorrect transparency display in 3D window
Windows 7 Professional 64-bit - Service Pack 1
NVidia GeForce GTX 760
Driver 9.18.13.3489
Blender 2.76 RC - 2015-09-17 - Hash: c586e30
3D windows set to material display. The second mesh plane (behind the first) is selected.
During animation playback mesh plane with animated transparency causes second mesh plane behind it to display with a hole at alpha values between 0 and 1
If the mesh plane at the front (with animated transparency) is selected during playback then the display problem does not occur.
Ignatz (ignatz) added a project: BF Blender.
Ignatz (ignatz) set Type to Bug.
Ignatz (ignatz) added a subscriber: Ignatz (ignatz).
Ignatz (ignatz) created this task.
Ignatz (ignatz) raised the priority of this task from to Needs Triage by Developer.
Sergey Sharybin (sergey) closed this task as Archived.
Sergey Sharybin (sergey) claimed this task.
3D viewport doesnt' do depth ordering of objects and always draws transparent objects in a separate pass in rather unpredictable for artists order. This might easily case artifacts like this to happen.
While it is possible to do proper ordering in the viewport it'll have negative effect on the viewport performance.
So thanks for the report, but it's not considered a bug.
