Particle instance uses rotation based on original extrude orientation when modeling instead of particle settings and particle Size doesn't affect particle instance. #46319
Reference: blender/blender#46319
Win10 and Win7 (tested both)
GTX TITAN 6gb
Broken: blender 2.76rc2, also tested on last Gooseberry build on buildbot. (more particle instance options but rotation still useless)
When using hair, and changing strands to object in render settings, objects recieve hair settings like size and rotation, but they can't be deformed by strands, so when you need this, particle instance modifier is necessary. However, in particle instance modifier, it is practically impossible to get your object instances rotate properly along normals since they rotate based on original extrude direction instead of particle settings. Also, size is broken, it only eliminates instances instead of changing their size. Only length gets tradueced to particle instance, but most of the time you also need things to be smaller.
blend file:
bug.blend
Added subscriber: @DavidFenner
Added subscriber: @zeauro
Hair particles rotation is ignored since a long period, now.
It is a known limitation.
In Gooseberry build, particles instance modifier have two settings that don't exist into master.
One to rotate instances and one to randomize rotation.
Randomization was main goal for gooseberry grass etc...
Orientation relative to extrusion seems to be a problem introduced by Gooseberry changes.
It did not happen in versions previous to 2.74.
Edit :
I forgot to precise that size is a term limited to emitter particles.
Hair particle thickness or width was always a global setting for all particles of the system.
It depends to material's strand settings for Blender Internal.
So, it is also a setting specific to Cycles when Cycles is used.
Added subscriber: @Sergey
Current particle system in Blender is quite fragile and missing some features because of stability reasons. It is on TODO to fully revisit particle system, but it'll take some time. For until then trying to solve issues with existing code will just break particles even more.
So thanks for the report, but closing as a known TODO/limitation.
