Crash right after BVH build completes when hair particles applied #46323
Closed
opened 2015-09-30 04:36:54 +02:00 by Paul J. Schrenker · 9 comments
AMD Phenom II X4 940
Win XP Home Edition, SP3, 32bit
4GB RAM
ATI Radeon HD 4200 (3.3.11672 Compatibility Profile Context)
Blender 2.76 RC2, hash: e24ea81
Bug behavior
Crash to desktop right before rendering starts as BVH completes.
Blender scene in Cycles with plane mesh. Mesh scaled up for use as ground plane, and scaling applied. Particles added to plane mesh and set to hair mode for use as grass. Particle count greater than 2000. Particle child count around 200. Render scene, crashes to desktop right as BVH build step completes at 100%.
Quirk to this crash behavior: If scene is saved with same settings before rendering, opening Blender with no other actions applied and re-loading the same scene (same particle count, etc.) the BVH build completes and the render progresses and completes without crashing to desktop. So a scene that crashes due to particles renders just fine if opened and tried again without altering any settings.
**System Information** AMD Phenom II X4 940 Win XP Home Edition, SP3, 32bit 4GB RAM ATI Radeon HD 4200 (3.3.11672 Compatibility Profile Context) **Blender Version** Blender 2.76 RC2, hash: e24ea81 **Bug behavior** Crash to desktop right before rendering starts as BVH completes. **Exact steps for others to reproduce the error** Blender scene in Cycles with plane mesh. Mesh scaled up for use as ground plane, and scaling applied. Particles added to plane mesh and set to hair mode for use as grass. Particle count greater than 2000. Particle child count around 200. Render scene, crashes to desktop right as BVH build step completes at 100%. Quirk to this crash behavior: If scene is saved with same settings before rendering, opening Blender with no other actions applied and re-loading the same scene (same particle count, etc.) the BVH build completes and the render progresses and completes without crashing to desktop. So a scene that crashes due to particles renders just fine if opened and tried again without altering any settings.
Added subscriber: @pauljs75
Added subscriber: @Sergey
Please always attach .blend file which demonstrates the issue.
But in fact it actually smells like an out of memory issue. On 32bit system you can never allocate more than 4gig of RAM. Now, doing any action in Blender will store undo steps in memory, which will lead to fewer memory availabel for Cycles.
But as said, in order to investigate this further we do need a .blend file with exact steps of reproducing the issue.
Please always attach .blend file which demonstrates the issue. But in fact it actually smells like an out of memory issue. On 32bit system you can never allocate more than 4gig of RAM. Now, doing any action in Blender will store undo steps in memory, which will lead to fewer memory availabel for Cycles. But as said, in order to investigate this further we do need a .blend file with exact steps of reproducing the issue.
Shed.blend
I suppose this may help. It was something quick I was messing with when having the particle-related crash and left at that stage. Reloading works, but may crash if changing around the particle settings.
[Shed.blend](https://archive.blender.org/developer/F241580/Shed.blend) I suppose this may help. It was something quick I was messing with when having the particle-related crash and left at that stage. Reloading works, but may crash if changing around the particle settings.
Member
Added subscriber: @Blendify
Member
Works fine here sounds like a memory issue
Sergey Sharybin self-assigned this 2015-10-04 09:11:34 +02:00
This file requires around 1.3gig of ram in peak (on 32bit linux system, where memory allocation is a bit better due to less fragmentation) which might be a tight fit for your 32bit system.
You can reduce number of global undo steps or limit them in memory. Also make sure you don't run some unneeded applications on the background.
Currently i don't see a bug here, it's really seems as an out of memory issue. Thanks for the report anyway.
This file requires around 1.3gig of ram in peak (on 32bit linux system, where memory allocation is a bit better due to less fragmentation) which might be a tight fit for your 32bit system. You can reduce number of global undo steps or limit them in memory. Also make sure you don't run some unneeded applications on the background. Currently i don't see a bug here, it's really seems as an out of memory issue. Thanks for the report anyway.
Reference: blender/blender#46323
