The bl_width_max property of nodes reset to 320 automatically #46345
6 Participants
Reference: blender/blender#46345
Windows 7 64 bit
Broken:
e511710
For some nodes it can be useful when they are wider than the normal max value of 320.
To make them wider I first increase the bl_width_max value of the node and then I change the real width.
This works all fine but sometimes the bl_width_max property resets back to 320 after saving, closing blender, and reopening the file again.
Why is there a max value anyway?
Added subscribers: @JulianEisel, @mont29
Please always include a .blend file and precise simple steps to reproduce reported issue…
@JulianEisel maybe you know about this and/or are interested to investigate too?
Ah sorry. Here the file. Just open it and try to make the node larger or smaller.
bl_width_max_bug.blend
Thanks, yes, something seems odd here… might be versionning too?
Added subscriber: @brecht
It shouldn't be possible to modify
bl_width_max
, that's a property of the node type not the node and should only be set when a node type is registered.I'm not sure why node types have these fairly limited max values, probably they could be increased.
Agree with @brecht. I'm not that familiar with RNA internals, but think we can just do this to disable tweaking for register values:
We can also easily increase max size for nodes, just depends on what value is appropriate. What about say 640?
Also, I think minwidth & maxwitdh should be scaled with U.pixelsize (at least maxwidth).
Added subscriber: @ideasman42
If that works and doesn't break registration that seems ok. Though would be good to check with @ideasman42 if there could be scripts depending on these being editable.
Regarding pixel size, I'm not sure why it should be scaled, I would expect the node editor to do that kind of conversion in the drawing code. There should be no detectable difference in the Python API as far as I know.
Increasing the 320 to some higher number would be ok for me but I wonder for what this property is needed and why it has to be such a 'low' value. Happens something bad when the width is 10.000 or so? Not that I need such a wide node, but why is there this limitation?
This issue was referenced by
867c49b962
LGTM, @JulianEisel, committed as you :)
@JacquesLucke, I see your point, question is if such huge values are any more useful. I don't think so, I'd say a default maxvalue of 640-1000 is okay.
Yes okay. I just found a work around for me.
All nodes in my Addon are subclasses of bpy.types.Node and AnimationNode. When I make bl_width_max = 5000 as class property of the AnimationNode class then all other nodes uses that max value.
But yes. I guess 1000 is definitly enouph.
Thanks! :)
