Motion blur acting up. #46404
Reference: blender/blender#46404
Windows8 x64 and Dual GTX 670s (but the problem still exists on CPU rendering - i7-3930k)
Broken: (example: 2.76 RC3
fb78f6d
Worked: Not sure, using most recent version of Blender RC3
Strange artifacts/displaced vertices in mesh when motion blur is enabled (images attached). The clean one is without MB.
I have animated a paper airplane being folded (armatures and shape keys), it randomly seems to happen in random spots. Only happens with motion blur enabled.
Added subscriber: @BraedenLaverty
I am using a mirror modifier and I found that by disabling the "merge" checkbox, this problem doesn't happen anymore... odd either way. Luckily I didnt need to use the merge setting for this, but hopefully this can be sorted out some how.
Added subscriber: @Sergey
It's really hard to tell what's going on there without having .blend file which demonstrates the issue.
Current guess is that with merge option either topology of the mesh change s cross the frames or order of output is not determenistic in certain cicrumstances which will surely confuse deformation motion blur.
In order to give any more definitive answer here we need .blend file.
Attached is the blend file. Frame 14 seems to be the only one that this happens to. To be fair to blender, the mesh is not great, I was just doing a test for something and wasn't super careful with it... but it just seemed odd that it would suddenly just do that during motion blur, seems like a bug.
paper_test.blend
Hope this helps. Let me know if I can do anything else.
Thanks!
Added subscriber: @brecht
The problem is indeed that the topology changes during motion blur, which is not supported. Cycles only checks that the number of vertices is the same, so it doesn't detect that the topology changes. But if it would have detected that you'd still have the problem that motion blur is disabled for this frame.
Perhaps the Mirror modifier could use undeformed coordinates to determine which vertices to merge, so that the topology stays the same. But this is a bit of an unusual setup in that typically the mirror modifier comes before the armature modifier, so that both sides can be animated independently.
Makes sense, as I mentioned, this was created in a hurry just for reference. I created a second version with cleaner topology and I used the same modifiers in the same order in the stack and it worked fine. As I am not a developer, I had no clue how the motion blur is calculated, knowing now that verts are checked, it makes complete sense that there was an error. Thanks for the reply, it is much appreciated. Oh, and thanks for all the awesomeness you have brought to Blender.
Added subscriber: @mont29
So, not a bug in the end, we can close it. ;)
