Point density textures. When using vertices as source, the viewport preview render does not update when adding a modifier or changing modifier settings.
Ubuntu 15.05 x64 Geforce GTX 580
Broken: f456c8d
When using vertices as input for point density and adding a modifer or changing settings of a modifier, the viewport does not update. Also when using subsurf modifier, it always uses the number of subdivisions in "render", even when in viewport preview render. See attached video:
Open attached .blend - go to rendered preview mode - change subsurf settings - remove and re-add the modifier. Nothing happens. When going out of rendered view and back in, the render amount of subdivisions is used, not the view one.
