[Material node editor] default value for "normal" input of a node group not taken into account #46406
5 Participants
Reference: blender/blender#46406
No matter
Broken: 2.75
A "normal" input is defined in a node group and a default value is set for this input (in the right panel of the node editor). If this input is not connected outside of the node group, the default value is not taken into account and the actual value is random.
No matter (see blend file)Bug_normal.blend
Added subscriber: @momotoh
Added subscriber: @mont29
This issue was referenced by
1730c3666f
307d4b3139
Added subscriber: @brecht
Changed status from 'Resolved' to: 'Open'
I've reverted this fix, since it's breaking Cycles node groups.
I think this was actually rendering correctly, it should not use the default value but the one in the group node. However the Normal input has its value hidden, which is confusing.
@brecht, you're right. Default value in the settings only affects newly added node group instances. That's a bit confusing (well, big enough to confuse myself :( ) from the UI interaction point of view but indeed everything worked as expected.
Improvements to communication are possible, but they're happening outside of the bug tracker.
@brecht, That being said, what if we simply expose vector value "editor" to the group node (similar to how it's done for other vector nodes like Vector Transform) ?
For BSDF nodes the vector value editor is hidden, because the value will not be used, it uses the surface normal. If you put that BSDF node in a group the flag to indicate that the editor should be hidden is inherited.
That's fine, the problem happens when you remove that BSDF node from the group, then hiding the value editor is wrong. It could be smarter about that, not sure what the best way to solve that would be.
This issue was referenced by blender/cycles@6973516c33
This issue was referenced by blender/cycles@68d42cca03
Changed status from 'Archived' to: 'Resolved'
Changed status from 'Resolved' to: 'Archived'
Eeh, porting commit to Cycles repository marked the report as resolved while in fact it's not resolved.
To be clear: there are actually several other issues reported here about behavior of node group inputs which are in fact related to this one. For example, you can't switch socket type from vector to color and vice versa.
While it's confusing, it's not really a bug since it actually behaves as it was intended from code side. Surely improvements are possible, we'll look into this as a part of TODO work. Noted the report there: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#Node_Editor
