Sculpt save bug #46471
Closed
opened 2015-10-13 19:52:00 +02:00 by Alexey · 7 comments
Broken: (all)
Worked: (none)
Leaf sculpt.blend1
open this file
draw anything(add any changes on model in sculpt mode)
try to close blender - we will not have this menu(message)
P.S. this error with sculpt mode only
**System Information** Operating system and graphics card **Blender Version** Broken: (all) Worked: (none) **Short description of error** ![1.png](https://archive.blender.org/developer/F244735/1.png) ![2.png](https://archive.blender.org/developer/F244737/2.png) **Exact steps for others to reproduce the error** [Leaf sculpt.blend1](https://archive.blender.org/developer/F244739/Leaf_sculpt.blend1) open this file draw anything(add any changes on model in sculpt mode) try to close blender - we will not have this menu(message) P.S. this error with sculpt mode only
Author
Author
Added subscriber: @Inwader77
Aaron Carlisle self-assigned this 2015-10-13 19:55:48 +02:00
Aaron Carlisle removed their assignment 2015-10-13 19:56:21 +02:00
Added subscribers: @ideasman42, @Sergey
Can confirm the issue. Here's a fix which solves it:
P269: Fix for #46471
diff --git a/source/blender/editors/sculpt_paint/paint_hide.c b/source/blender/editors/sculpt_paint/paint_hide.c
index 2f1d4cd..5af6792 100644
--- a/source/blender/editors/sculpt_paint/paint_hide.c
+++ b/source/blender/editors/sculpt_paint/paint_hide.c
@@ -417,7 +417,7 @@ static int hide_show_exec(bContext *C, wmOperator *op)
 		MEM_freeN(nodes);
 	/* end undo */
-	sculpt_undo_push_end();
+	sculpt_undo_push_end(C);
 	/* ensure that edges and faces get hidden as well (not used by
 	 * sculpt but it looks wrong when entering editmode otherwise) */
diff --git a/source/blender/editors/sculpt_paint/paint_mask.c b/source/blender/editors/sculpt_paint/paint_mask.c
index 118f3a7..2f63146 100644
--- a/source/blender/editors/sculpt_paint/paint_mask.c
+++ b/source/blender/editors/sculpt_paint/paint_mask.c
@@ -133,7 +133,7 @@ static int mask_flood_fill_exec(bContext *C, wmOperator *op)
 	if (multires)
 		multires_mark_as_modified(ob, MULTIRES_COORDS_MODIFIED);
 	if (nodes)
 		MEM_freeN(nodes);
@@ -265,7 +265,7 @@ int ED_sculpt_mask_box_select(struct bContext *C, ViewContext *vc, const rcti *r
 	if (multires)
 	ED_region_tag_redraw(ar);
@@ -420,7 +420,7 @@ static int paint_mask_gesture_lasso_exec(bContext *C, wmOperator *op)
 		if (multires)
 		ED_region_tag_redraw(vc.ar);
 		MEM_freeN((void *)mcords);
diff --git a/source/blender/editors/sculpt_paint/sculpt.c b/source/blender/editors/sculpt_paint/sculpt.c
index 07511e1..81c158a 100644
--- a/source/blender/editors/sculpt_paint/sculpt.c
+++ b/source/blender/editors/sculpt_paint/sculpt.c
@@ -4522,7 +4522,7 @@ static void sculpt_stroke_done(const bContext *C, struct PaintStroke *UNUSED(str
 		sculpt_cache_free(ss->cache);
 		ss->cache = NULL;
 		BKE_pbvh_update(ss->pbvh, PBVH_UpdateOriginalBB, NULL);
@@ -4846,7 +4846,7 @@ static int sculpt_dynamic_topology_toggle_exec(bContext *C, wmOperator *UNUSED(o
 		sculpt_dynamic_topology_enable(C);
 		sculpt_undo_push_node(ob, NULL, SCULPT_UNDO_DYNTOPO_BEGIN);
 	return OPERATOR_FINISHED;
@@ -5008,7 +5008,7 @@ static int sculpt_symmetrize_exec(bContext *C, wmOperator *UNUSED(op))
 	/* Finish undo */
 	BM_log_all_added(ss->bm, ss->bm_log);
 	/* Redraw */
 	sculpt_pbvh_clear(ob);
@@ -5216,7 +5216,7 @@ static int sculpt_detail_flood_fill_exec(bContext *C, wmOperator *UNUSED(op))
 	MEM_freeN(nodes);
 	/* force rebuild of pbvh for better BB placement */
diff --git a/source/blender/editors/sculpt_paint/sculpt_intern.h b/source/blender/editors/sculpt_paint/sculpt_intern.h
index 8f1a465..51af878 100644
--- a/source/blender/editors/sculpt_paint/sculpt_intern.h
+++ b/source/blender/editors/sculpt_paint/sculpt_intern.h
@@ -118,7 +118,7 @@ typedef struct SculptUndoNode {
 SculptUndoNode *sculpt_undo_push_node(Object *ob, PBVHNode *node, SculptUndoType type);
 SculptUndoNode *sculpt_undo_get_node(PBVHNode *node);
 void sculpt_undo_push_begin(const char *name);
-void sculpt_undo_push_end(void);
+void sculpt_undo_push_end(const struct bContext *C);
 void sculpt_vertcos_to_key(Object *ob, KeyBlock *kb, float (*vertCos)[3]);
diff --git a/source/blender/editors/sculpt_paint/sculpt_undo.c b/source/blender/editors/sculpt_paint/sculpt_undo.c
index 1f1be51..6028f2c 100644
--- a/source/blender/editors/sculpt_paint/sculpt_undo.c
+++ b/source/blender/editors/sculpt_paint/sculpt_undo.c
@@ -884,8 +884,9 @@ void sculpt_undo_push_begin(const char *name)
 	                         sculpt_undo_restore, sculpt_undo_free, sculpt_undo_cleanup);
+void sculpt_undo_push_end(const bContext *C)
+	wmWindowManager *wm = CTX_wm_manager(C);
 	ListBase *lb = undo_paint_push_get_list(UNDO_PAINT_MESH);
 	SculptUndoNode *unode;
@@ -901,4 +902,10 @@ void sculpt_undo_push_end(void)
 	ED_undo_paint_push_end(UNDO_PAINT_MESH);
+	/* TODO(sergey): Could this be de-duplicated with regular undo? */
+	if (wm->file_saved) {
+		wm->file_saved = 0;
+		WM_event_add_notifier(C, NC_WM | ND_DATACHANGED, NULL);
@ideasman42, i'm kind of struggling about those few lines being duplicated across global undo and sculpt undo. Points:
  1. The code will need to be added to other local undo stacks
  2. It's few lines of code, could we really make meaningful function for them? Maybe call WM_tag_file_dirty(bContext *C)?
Can confirm the issue. Here's a fix which solves it: [P269: Fix for #46471](https://archive.blender.org/developer/P269.txt) ``` diff --git a/source/blender/editors/sculpt_paint/paint_hide.c b/source/blender/editors/sculpt_paint/paint_hide.c index 2f1d4cd..5af6792 100644 --- a/source/blender/editors/sculpt_paint/paint_hide.c +++ b/source/blender/editors/sculpt_paint/paint_hide.c @@ -417,7 +417,7 @@ static int hide_show_exec(bContext *C, wmOperator *op) MEM_freeN(nodes); /* end undo */ - sculpt_undo_push_end(); + sculpt_undo_push_end(C); /* ensure that edges and faces get hidden as well (not used by * sculpt but it looks wrong when entering editmode otherwise) */ diff --git a/source/blender/editors/sculpt_paint/paint_mask.c b/source/blender/editors/sculpt_paint/paint_mask.c index 118f3a7..2f63146 100644 --- a/source/blender/editors/sculpt_paint/paint_mask.c +++ b/source/blender/editors/sculpt_paint/paint_mask.c @@ -133,7 +133,7 @@ static int mask_flood_fill_exec(bContext *C, wmOperator *op) if (multires) multires_mark_as_modified(ob, MULTIRES_COORDS_MODIFIED); - sculpt_undo_push_end(); + sculpt_undo_push_end(C); if (nodes) MEM_freeN(nodes); @@ -265,7 +265,7 @@ int ED_sculpt_mask_box_select(struct bContext *C, ViewContext *vc, const rcti *r if (multires) multires_mark_as_modified(ob, MULTIRES_COORDS_MODIFIED); - sculpt_undo_push_end(); + sculpt_undo_push_end(C); ED_region_tag_redraw(ar); @@ -420,7 +420,7 @@ static int paint_mask_gesture_lasso_exec(bContext *C, wmOperator *op) if (multires) multires_mark_as_modified(ob, MULTIRES_COORDS_MODIFIED); - sculpt_undo_push_end(); + sculpt_undo_push_end(C); ED_region_tag_redraw(vc.ar); MEM_freeN((void *)mcords); diff --git a/source/blender/editors/sculpt_paint/sculpt.c b/source/blender/editors/sculpt_paint/sculpt.c index 07511e1..81c158a 100644 --- a/source/blender/editors/sculpt_paint/sculpt.c +++ b/source/blender/editors/sculpt_paint/sculpt.c @@ -4522,7 +4522,7 @@ static void sculpt_stroke_done(const bContext *C, struct PaintStroke *UNUSED(str sculpt_cache_free(ss->cache); ss->cache = NULL; - sculpt_undo_push_end(); + sculpt_undo_push_end(C); BKE_pbvh_update(ss->pbvh, PBVH_UpdateOriginalBB, NULL); @@ -4846,7 +4846,7 @@ static int sculpt_dynamic_topology_toggle_exec(bContext *C, wmOperator *UNUSED(o sculpt_dynamic_topology_enable(C); sculpt_undo_push_node(ob, NULL, SCULPT_UNDO_DYNTOPO_BEGIN); } - sculpt_undo_push_end(); + sculpt_undo_push_end(C); return OPERATOR_FINISHED; } @@ -5008,7 +5008,7 @@ static int sculpt_symmetrize_exec(bContext *C, wmOperator *UNUSED(op)) /* Finish undo */ BM_log_all_added(ss->bm, ss->bm_log); - sculpt_undo_push_end(); + sculpt_undo_push_end(C); /* Redraw */ sculpt_pbvh_clear(ob); @@ -5216,7 +5216,7 @@ static int sculpt_detail_flood_fill_exec(bContext *C, wmOperator *UNUSED(op)) } MEM_freeN(nodes); - sculpt_undo_push_end(); + sculpt_undo_push_end(C); /* force rebuild of pbvh for better BB placement */ sculpt_pbvh_clear(ob); diff --git a/source/blender/editors/sculpt_paint/sculpt_intern.h b/source/blender/editors/sculpt_paint/sculpt_intern.h index 8f1a465..51af878 100644 --- a/source/blender/editors/sculpt_paint/sculpt_intern.h +++ b/source/blender/editors/sculpt_paint/sculpt_intern.h @@ -118,7 +118,7 @@ typedef struct SculptUndoNode { SculptUndoNode *sculpt_undo_push_node(Object *ob, PBVHNode *node, SculptUndoType type); SculptUndoNode *sculpt_undo_get_node(PBVHNode *node); void sculpt_undo_push_begin(const char *name); -void sculpt_undo_push_end(void); +void sculpt_undo_push_end(const struct bContext *C); void sculpt_vertcos_to_key(Object *ob, KeyBlock *kb, float (*vertCos)[3]); diff --git a/source/blender/editors/sculpt_paint/sculpt_undo.c b/source/blender/editors/sculpt_paint/sculpt_undo.c index 1f1be51..6028f2c 100644 --- a/source/blender/editors/sculpt_paint/sculpt_undo.c +++ b/source/blender/editors/sculpt_paint/sculpt_undo.c @@ -884,8 +884,9 @@ void sculpt_undo_push_begin(const char *name) sculpt_undo_restore, sculpt_undo_free, sculpt_undo_cleanup); } -void sculpt_undo_push_end(void) +void sculpt_undo_push_end(const bContext *C) { + wmWindowManager *wm = CTX_wm_manager(C); ListBase *lb = undo_paint_push_get_list(UNDO_PAINT_MESH); SculptUndoNode *unode; @@ -901,4 +902,10 @@ void sculpt_undo_push_end(void) } ED_undo_paint_push_end(UNDO_PAINT_MESH); + + /* TODO(sergey): Could this be de-duplicated with regular undo? */ + if (wm->file_saved) { + wm->file_saved = 0; + WM_event_add_notifier(C, NC_WM | ND_DATACHANGED, NULL); + } } ``` @ideasman42, i'm kind of struggling about those few lines being duplicated across global undo and sculpt undo. Points: 1. The code will need to be added to other local undo stacks 2. It's few lines of code, could we really make meaningful function for them? Maybe call `WM_tag_file_dirty(bContext *C)`?
Sergey Sharybin self-assigned this 2015-10-14 20:43:31 +02:00
Since this is using a global list anyway, its tempting to do this... (patch below)
However, using wm->first is weak, suggest to apply your patch, but move TODO(sergey): Could this be de-duplicated with regular undo? block into a function. WM_file_tag_modified ? - since we have other WM_file_* functions.
P270: #46471 hack
diff --git a/source/blender/editors/sculpt_paint/paint_undo.c b/source/blender/editors/sculpt_paint/paint_undo.c
index 42f0aaa..73bde87 100644
--- a/source/blender/editors/sculpt_paint/paint_undo.c
+++ b/source/blender/editors/sculpt_paint/paint_undo.c
@@ -33,10 +33,15 @@
 #include "BLI_string.h"
 #include "DNA_userdef_types.h"
+#include "DNA_windowmanager_types.h"
 #include "BKE_blender.h"
 #include "BKE_context.h"
 #include "BKE_global.h"
+#include "BKE_main.h"
+#include "WM_api.h"
+#include "WM_types.h"
 #include "ED_paint.h"
@@ -287,6 +292,15 @@ void undo_paint_push_count_alloc(int type, int size)
 void ED_undo_paint_push_end(int type)
+	/* XXX, this is called outside the main undo stack */
+		wmWindowManager *wm = G.main->wm.first;
+			WM_main_add_notifier(NC_WM | ND_DATACHANGED, NULL);
 	if (type == UNDO_PAINT_IMAGE)
 		undo_stack_push_end(&ImageUndoStack);
 	else if (type == UNDO_PAINT_MESH)
Since this is using a global list anyway, its tempting to do this... (patch below) However, using `wm->first` is weak, suggest to apply your patch, but move `TODO(sergey): Could this be de-duplicated with regular undo?` block into a function. `WM_file_tag_modified` ? - since we have other `WM_file_*` functions. [P270: #46471 hack](https://archive.blender.org/developer/P270.txt) ```diff diff --git a/source/blender/editors/sculpt_paint/paint_undo.c b/source/blender/editors/sculpt_paint/paint_undo.c index 42f0aaa..73bde87 100644 --- a/source/blender/editors/sculpt_paint/paint_undo.c +++ b/source/blender/editors/sculpt_paint/paint_undo.c @@ -33,10 +33,15 @@ #include "BLI_string.h" #include "DNA_userdef_types.h" +#include "DNA_windowmanager_types.h" #include "BKE_blender.h" #include "BKE_context.h" #include "BKE_global.h" +#include "BKE_main.h" + +#include "WM_api.h" +#include "WM_types.h" #include "ED_paint.h" @@ -287,6 +292,15 @@ void undo_paint_push_count_alloc(int type, int size) void ED_undo_paint_push_end(int type) { + /* XXX, this is called outside the main undo stack */ + { + wmWindowManager *wm = G.main->wm.first; + if (wm->file_saved) { + wm->file_saved = 0; + WM_main_add_notifier(NC_WM | ND_DATACHANGED, NULL); + } + } + if (type == UNDO_PAINT_IMAGE) undo_stack_push_end(&ImageUndoStack); else if (type == UNDO_PAINT_MESH) ```
This issue was referenced by fd1487977b
This issue was referenced by fd1487977b0d1a24b2076e1bdf72b6102821e6e4
Reference: blender/blender#46471
