Scaling in edit mode with individual origins and snapping activated is broken
Open, Confirmed, MediumPublic
Win7 x64
Broken: 2.76
Following T39161. Scaling in edit mode works well with "median" as pivot point but with "individual origins" it breaks.
In attached file:
Scale and choose a vertex with "ctrl" pressed, cube seems to disappear.
To compare, press "G" and choose a vertex for snap, the cube's center is moved as a cube (also individual origins could make all selected verts move to that position making a point instead of a cube?) to that vertex.
Scale with "median" as pivot, it works
So maybe to make it consistent, make "individual origins behave like median.
mathieu menuet (bliblubli) created this task.
mathieu menuet (bliblubli) raised the priority of this task from to Needs Triage by Developer.
Campbell Barton (campbellbarton) triaged this task as Confirmed, Medium priority.
Note that this was never supported and while we can support - it will take a bit of work to do it efficiently. Since we probably dont want to calculate this value for every element when its only going to be used in a specific case.
well, don't loose your time finding a real solution for this one until someone comes with a real use case for it. But in the mean time, making it behave like in the " median" case instead of making it disappear would help.
I found another but by the way. When you scale on x,y (with shift+z), it seems the algorithm takes the z component into account also it is not used.
Step to reproduce:
  • Open this file:
In the left perspective view:
  • Press S
  • Press shift+Z
  • Hold ctrl to snap and hover the bottom right vertex of the other cube.
Look on the right top view, the cube is not scaled up to the chosen point. Doing the same with grabbing instead of scaling works.
I can open another bug report if you want.
Setting this as Todo, seems this is just not supported yet (leaving it open though, so Campbell doesn't forget about it ;) ).
Julian Eisel (Severin) changed Type from Bug to To Do.Nov 6 2015, 12:44 AM
