Unwrap UV with "use subdivision modifier" does not work
OSX 10.6.8 Ati Radeon HD 2400
Broken: 2.76 (6158a98) Blender buildbot and official 2.76 +2.75 releases
Worked: 2.74
If i Unwrap model with "use subdivision modifier" on, it gives unexpected results(single faces are unwrapped
I uploaded also a example blend file : Unwrap the mesh and turn "use sudivision mod."on.
Revisions and Commits
Hakan Tunc (Tunge) raised the priority of this task from to 90.
Hakan Tunc (Tunge) updated the task description. (Show Details)
Hakan Tunc (Tunge) added a project: BF Blender.
Hakan Tunc (Tunge) edited a custom field.
Bastien Montagne (mont29) renamed this task from Unwrap UV with "use subdivision modifier" to Unwrap UV with "use subdivision modifier" does not work.Oct 18 2015, 3:26 PM
Bastien Montagne (mont29) removed Antonis Ryakiotakis (psy-fi) as the assignee of this task.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.
Bastien Montagne (mont29) updated the task description. (Show Details)
@Hakan Tunc (Tunge) please do not make wild assignments that way…
@Sergey Sharybin (sergey) @Campbell Barton (campbellbarton) @Antonis Ryakiotakis (psy-fi) ideas here? Feature works in 2.75, but I can think of several changes in 2.76 that could cause that (subsurf changes themselves of course, OSD, looptris…).
OpenSubdiv integration doesn't have UVs support yet. But other than that it should all work as it used to. Needs some more investigation, don't currenty have time for this tonight. Can have a closer look later.
Campbell Barton (campbellbarton) renamed this task from Unwrap UV with "use subdivision modifier" does not work to Unwrap UV with "use subdivision modifier" does not work w/ OpenSubdiv.Oct 19 2015, 9:43 AM
Bastien Montagne (mont29) renamed this task from Unwrap UV with "use subdivision modifier" does not work w/ OpenSubdiv to Unwrap UV with "use subdivision modifier" does not work.Oct 19 2015, 9:46 AM
@Campbell Barton (campbellbarton) it does not work either without OSD…
Right, looks like issue with it expecting tessface, looking into fix.
