FCurve Modifier parameter is changed only with time change
W10 64b
2.76
I don`t know if it is limitation or bug, but if you change any parameter in modifier, it is not visible until you change time.
  1. open:
  2. select Y Location curve in F-Curve
  3. change "y =" parameter
  4. cube stay without move until you play animation
Same happen in all modifiers. Sometimes it is good if you have feedback immediatelly ;)
Btw. it would be awesome, if there will be some modifier for offseting channels. So animator can use same animation clip, but only with same offset for translate X, some another offset for translate Y .. etc.
I loved it in the Softimage: http://download.autodesk.com/global/docs/softimage2014/en_us/index.html?url=files/actions_OffsettingActionValueswithanOffsetMap.htm,topicNumber=d30e185446
Cenek Strichel (cenda) raised the priority of this task from to Needs Triage by Developer.
Cenek Strichel (cenda) updated the task description. (Show Details)
Cenek Strichel (cenda) set Type to Bug.
Bastien Montagne (mont29) renamed this task from Modifier parameter is changed only with time change to FCurve Modifier parameter is changed only with time change.Oct 22 2015, 5:54 PM
Bastien Montagne (mont29) lowered the priority of this task from Needs Triage by Developer to Normal.
