Deselect Linked Seam fails ( Deselects all instead )
Select linked with a mesh which has UV seams works. However if you try to deselect with Shift+L it fails and deselects all instead.
Regression in 2.76 Official
Also tested on 2.76 85072eb
Windows 64 Bit
Fasit (ygtsvtr) raised the priority of this task from to 90.
Fasit (ygtsvtr) updated the task description. (Show Details)
Fasit (ygtsvtr) added a project: BF Blender.
Fasit (ygtsvtr) edited a custom field.
Fasit (ygtsvtr) added a subscriber: Fasit (ygtsvtr).
Fasit (ygtsvtr) changed the task status from Unknown Status to Archived.Oct 22 2015, 9:50 AM
Fasit (ygtsvtr) claimed this task.
I forgot that vertex mode and edge mode are not supported. My bad. I'm marking this as invalid but maybe a todo is necessary ? since vertex and edge modes are used pretty often.
It turns out this was a bug, since it also happened without sync select being enabled too.
Also, vert/edge now support select linked rB72b422c1e101: UV: support select linked with sync-select in vert/edge modes.
