Add Object logic brick broken in 2.76
Windows 7 x64
NVIDIA GeForce GTX 980
Broken: 2.76b f337fea (Also tested 2.76)
When using the BGE logic brick "Edit Object" set to "Add Object", triggered by any event, keyboard or delay, etc. the specified object does not spawn.
Add a cube and an empty to your scene
Give the empty "Add Object" logic triggered by a keyboard event
Press P and then whatever key you assigned to the keyboard event
It is not a bug but expected behaviour.
As mentioned in the tooltip, added object must be on an invisible layer.
Move your bomb object to an other layer and it will work as expected.
Jorge Bernal (lordloki) changed the task status from Unknown Status to Archived.Nov 5 2015, 3:42 PM
Jorge Bernal (lordloki) claimed this task.
@ronan ducluzeau (zeauro) is right.
I close as it is not a bug.
Thanks for reporting.
Thank you, sorry about that. Been a long time since I used the BGE, I should have remembered that though.
