Blender Render Texture and Material Views Show Large Wireframes when viewing OpenSubDiv Objects #46706
6 Participants
Reference: blender/blender#46706
Windows 10 Pro x64
Broken: 2.76
48f7dd6
When viewing an object using OpenSubDiv with Texture or Material mode in Blender Internal, the object is shown as if it was using a thick wireframe modifier.
Setup: Create an object of any sort, add a subsurf with at least one subdivision. Enable OpenSubDiv.
It seems that Material mode does this with both Multitexture, and GLSL, but Texture mode is only effected under GLSL.
Here's an example with a Cube subdivided twice:
Added subscriber: @DBrown
Added subscriber: @Sergey
I can not reproduce the issue with the given steps. please:
Help -> System Info
My sincere apologies:
CPU: AMD FX 8350
CPU Chipset: 990fx
Video Card: XFX AMD R9 390
Catalyst Version: 15.7.1 (Latest stable)
Tested latest and daily (same results):
2.76b #f337fea
2.76.2 #4b316e7
*I installed the AMD Catalyst 15.11 beta drivers, which also gave the same results.
I tried OpenSubDIv in both CPU, and GLSL Transform Feedback, and both gave the same results (GLSL Compute not available).
I'm sure it doesn't make any difference, but when deselected, it shows as bands (screenshots attached).
Here is the blend file, putting you exactly where I was in the screenshots:
osd_test.blend
and here is my system-info:
system-info.txt
Added subscriber: @mont29
Thanks for the info. For what is worth, cannot reproduce this here (nvidia 850m, debian64 testing). Probably something related to that GPU/driver?
Somehow this didn't submit earlier this week, but I have to agree it has to be a GPU issue, as I didn't have these issues with the nVidia 960 I replaced with the 390.
Here are the errors given when this happens:
Added subscriber: @MikeErwin
Same problem here. The "thick wireframe" is the standard selection outline. Usually you'd see just the silhouette, but when something goes wrong...
One of our shaders fails to compile when switching to material display mode. Also matcaps in solid display mode.
Intel driver's GLSL compiler on Windows 10 complains:
GPUShader: compile error:
ERROR: 3:8: 'varying' : cannot be a struct
ERROR: 3:27: 'varposition' : undeclared identifier
ERROR: 3:27: 'assign' : cannot convert from '3-component vector of float' to 'float'
ERROR: 3:28: 'varnormal' : undeclared identifier
ERROR: 3:28: 'assign' : cannot convert from '3-component vector of float' to 'float'
ERROR: 3:42: 'outpt' : undeclared identifier
ERROR: 3:42: 'v' : field selection requires structure, vector, or matrix on left hand side
ERROR: 3:42: 'position' : field selection requires structure, vector, or matrix on left hand side
ERROR: 3:42: 'assign' : cannot convert from '4-component vector of float' to 'float'
ERROR: 3:43: 'v' : field selection requires structure, vector, or matrix on left hand side
ERROR: 3:43: 'normal' : field selection requires structure, vector, or matrix on left hand side
According to grep, "varposition" is found in gpu_shader_[geometry|vertex|vertex_world].glsl
Reproduced problem on AMD A8-4555M running Windows 10. Shader compiler gave exact same errors as DBrown above.
Errors reported in my previous comment are from an Intel Haswell i5-4670.
Making some progress! Matcap and Cycles material preview are now working. No BI material preview yet. Haswell not working but for a different reason now. So it's not ready to commit yet. I will continue with this tomorrow.
Bumped GLSL from 1.3 to 1.5 (ARB_compatibility enabled) to get it working, plus changes to codegen and the OSD display shader.
{F254639}
Ok, got Intel Haswell working too. Changed
which works fine on AMD to
which should work everywhere. GLSL spec says this is the proper way.
Basic uniform materials (for BI or Cycles) are working now in Texture and Material display modes. Anything with UV maps needs additional work, as @Sergey mentioned in the OpenSubdiv release notes.
@MikeErwin, will you commit the fix?
@Sergey The current fix involves upgrading all codegen to GLSL 1.5. Which is great for Blender 2.8 but committing as is would break Mac builds and get in the way of 2.77. I'll try to make a minimal fix that is compatible with GLSL 1.2 and uses GLSL 1.5 (compatibility profile) just for the OSD parts.
I'll focus on this and should close before the weekend.
(except UV maps, that will take longer)
@MikeErwin, sounds cool. And yes, don't touch UVs yet, it's more complicated topic and we can collaborate on this in IRC perhaps.
This issue was referenced by
f997449f84
Changed status from 'Resolved' to: 'Open'
Partially resolved by recent commit.
Matcaps now work with OpenSubdiv, as do basic materials. Anything with UV coordinates is still broken.
+1 to working with @Sergey on UV part
Added subscriber: @brecht
Archiving old report, we no longer work on fixing these types of issues in 2.79 but focus on the new viewport in 2.8.
