Absolute Grid Alignment should perhaps NOT do third axis in orthographic views
Closed, InvalidPublic
OSX 10.11.2, NVIDIA GeForce GTX 680MX 2048 MB
Broken: 2.76b
I'm not 100% sure if this will be agreed to. When using Absolute Grid Snap in orthographic views (e.g. Top), I would have expected the snap to limit itself to X and Y, I can make this happen by pressing Shift+Z. Ether an option to only snap in 2 dimensions - perhaps a modifier key? would be really nice.
Related Objects
Andrei Nadin (AnadinX) raised the priority of this task from to Needs Triage by Developer.
Andrei Nadin (AnadinX) updated the task description. (Show Details)
Andrei Nadin (AnadinX) set Type to Bug.
Does it happen in top view that your Object is moved in Z-direction? It should only move in x/y direction in top view, also when its not locked to this directions.
This isn't a bug, current behavior works as intended based on T42632.
